"Service Theft Deterrent System" And a bunch of other warnings... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 1 Old 03-11-2017, 10:05 AM Thread Starter
Exclamation "Service Theft Deterrent System" And a bunch of other warnings...
I've been searching the web and the forums for an issue I'm having, but no luck. I have a 2012 2SS/RS (LS3) and I recently installed the Hurst Roll control kit. After checking for leaks and bleeding the brakes, I started her up and I started getting all kinds of warning lights. (i.e. Service Theft Deterrent, Service Tire Monitoring System, Service Parking Assist) just to name a few. The gauges sometimes work or sometime don't after starting it. The wipers come on and stay on while the switch is off, the headlights flicker and all the Stabilitrak dash lights are lit. I've had to reset by pulling the battery terminals a few times; had the battery tested and I'm still having the same issue. Currently I'm down to just the "Service Stabilitrak", but as I try other things, the previous warnings come back up and I have to pull the terminals again and start over. I've already spoken to Phastek and Hurst and according to them they have never had anyone with their kit causing such issues. Is this going to be a dealer only deal or is there something else I can try? Will reflashing the ECM with the current tune I have stored help?
ID:	50338   Click image for larger version
ID:	50346   Click image for larger version
sojo88 is offline
Human Verification
