posi-traction, which have it? - Page 3 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Drivetrain Discussion Automatic | Manual | Drivetrain | Gears & Axles
post #21 of 60 Old 02-03-2011, 03:50 PM
CamaroFTW's Avatar
Originally Posted by Wertman94 View Post
All this and nobody just went out and did a burnout to see?
the icy roads were enough for me to tell
2011 Chevy Camaro 2LT/RS Convertible Auto, CGM
2010 Chevy Camaro 1LT 3.6L Manual [Production #115] Black with cyber grey stripes (http://www.cardomain.com/ride/3370622) Traded 12/10/11
August 2011 MotM
-"Team LLT" representative
South Jersey Camaro Club member
CamaroFTW is offline
post #22 of 60 Old 02-20-2011, 03:57 PM
no posi rears in any camaro.
5th gen camaro as well as 4th gen fbody use a torsen differential which have no clutches so they are not a posi.they call them a limited slip which is not the same as a posi.They also suck in the snow.I changed my firehawk to an eaton posi and it made a huge difference at the track and in the snow.
firehawk952 is offline
post #23 of 60 Old 02-20-2011, 05:23 PM
54inches's Avatar
Limited slip IS a posi;torsen or clutch type, they are both LSD.
You are referring to a locker.
54inches is offline
post #24 of 60 Old 02-20-2011, 07:17 PM
Yellow 2SS's Avatar
http://auto.howstuffworks.com/differential4.htm LSD
http://auto.howstuffworks.com/differential6.htm Torsen
The 5th gen rear diff's are definately CLUTCH type LSD's!
Thus, when coasting, the clutches slip. And under throttle, the clutches grab
and "lock" up to the designed breaking torque, which they will break free and slip. As the clutch type get worn they will "one leg" just like an open diff.
The 5th gen uses a plate type clutch as opposed to the cone style.
These last longer and can be rebuilt easily and possible upgraded to stronger bias springs.
Randy
#4645
Yellow 2SS is offline
post #25 of 60 Old 02-20-2011, 09:13 PM
I'm running 3.70's and leave two black marks everytime I Mash on the Pedal hard enough.
IF I were running a Solid rear Axle I would be Running 3.90's and a detroit locker.
Jekyll-N-Hyde is offline
post #26 of 60 Old 02-21-2011, 07:13 AM
I wonder why GM did not give the auto the LSD. Do they think the people with autos don't play around. Just asking. I uploaded the 2011 spec sheet.
post #27 of 60 Old 02-21-2011, 10:32 AM
I dont know if its me or you reading it wrong but just like 2010
Both v8 models ( manual and auto ) get the LSD
The manual V6 gets the LSD but the Automatic doesnt.
post #28 of 60 Old 02-21-2011, 02:59 PM
No, your right, I knew that. But I still wonder why GM did not just give the v6 auto LSD..
post #29 of 60 Old 02-23-2011, 08:34 AM
GTRMAN's Avatar
I've had 5 Camaros now, and I've never done a burnout...
GTRMAN is offline
post #30 of 60 Old 02-23-2011, 05:10 PM
54inches's Avatar
Do you mean real Camaros and not Hot Wheels?
54inches is offline
Human Verification
