TR6060 Grinding in Second When Cold - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Drivetrain Discussion Automatic | Manual | Drivetrain | Gears & Axles
post #1 of 4 Old 02-16-2017, 05:45 AM Thread Starter
Like the title says lol. The second gear syncro seems to be hit or miss before the transmission has come up to temp. Basic googling shows this is a pretty common problem for this transmission. My question is, has anyone on here solved this issue, and if so, what did you do?
Typically I just shift 1-3 till the trans warms up, but it'd be nice to have second sooner...
And yes, double clutching works, but I want a "normal" fix...
2005 Silverado Z71 Crew Cab
2" Rough Country Leveling Kit, K&N Intake, custom Flowmaster 40 Series exhaust, Alpine sound system.
2012 Camaro 2SS
K&N Intake, Flowmaster Outlaw catback exhaust.
I'm not brand loyal, I'm pushrod loyal.
Phil_M is offline
post #2 of 4 Old 02-19-2017, 01:45 PM
How many miles, and have you checked/changed the fluid?
James 1:25 *I don't tolerate fools.* Ordered from Faulkner Chevy #NKCF02 1100 5/8/9 2000, 3300 7/16/9 TPW 7/20,GOT MY (low) VIN! 4000 7/24/9 ,Picked up 8/7/9!!! Signed Litho #45. Car signed by FBodfather 2011. Service: Jennings Chevy in PA. We don't "drift" kiddies... it's a POWER SLIDE! MOTM/COTM Sept 2012 Pro Patria Vigilans.
Click the pic..
post #3 of 4 Old 02-19-2017, 02:03 PM Thread Starter
Just over 14k miles. Only does it when cold, and by cold I mean under about 70/80 degrees or so. No, I haven't checked the fluid yet, though none of the other gears have any issues. Supposedly a dedicated clutch reservoir has helped some folks, and has the advantage of isolating the clutch from the brake system. Others recommend a different trans fluid.
I'm planning on getting the dedicated reservoir/replacing the trans fluid, but in the meantime I was curious if anyone on here had any experience with this issue.
2012 Camaro 2SS
Phil_M is offline
post #4 of 4 Old 04-18-2017, 01:13 PM
赤い 竜
Nancygrl's Avatar
Heck...I remember my '96 TransAm being that way in 2nd gear when cold. My 2011 Camaro SS also did it as well. Adding the separate reservoir for the clutch helped and I also changed out my transmission fluid at 8k miles to Amsoil and that seemed to make the biggest difference in shifting thru all the gears.
Nancy..........2017 ZL1, M6, NPP - Red Dragon (Chaos)
Previous rides: 2011 2SS M6, 2013 Hotwheels RS-A6, 2015 1SS/1LE M6, 2016 2SS-A8
Nancygrl is online now
Human Verification
