remote turn on for aftermarket amp - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 08-27-2009, 11:07 AM Thread Starter
10KAMP311's Avatar
I found the factory amp, but it is always on. Want to run an amp but not sure if I want it on all the time. Checked the rear fuse panel for an igniton switched lead but no luck.
10KAMP311 is offline
post #2 of 5 Old 08-27-2009, 01:11 PM
Steve@Subthump's Avatar
That's the way my sub amp is. On when the factory amp is on. No big deal though really. The only way to have it on switched power is to run a wire from your amp to the front, put in a switch, and then run it all the way back. Or else pull the radio and find the amp remote wire, splice in, add your switch and then go to the back. More work than I had time for.
Steve@Subthump is offline
post #3 of 5 Old 08-27-2009, 01:13 PM
Especially when you can just turn down the bass or volume...
Devryn is offline
post #4 of 5 Old 08-28-2009, 11:59 AM Thread Starter
10KAMP311's Avatar
sub box
Here are some pics of my box amd amp one jl 12" w3 2 ohm sub and and alpine class d mono amp with a line out converter.
Name:	sub box and amp 2010 camaro 006.jpg
ID:	3369   Click image for larger version
Name:	sub box and amp 2010 camaro 004.jpg
ID:	3370   Click image for larger version
Name:	sub box and amp 2010 camaro 003.jpg
ID:	3371   Click image for larger version
Name:	sub box and amp 2010 camaro 005.jpg
post #5 of 5 Old 08-28-2009, 07:32 PM
With the BA system, if your aftermarket amp has the remote on feature, like most do. You can use the white wire(pin 1) at connector X3 to tell your amp to turn on.
That is what I did, then power came straight from the battery below.
scourage is offline
Human Verification
