Removal of the 3rd brake light section, need help - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 01-10-2011, 09:46 AM Thread Starter
I'm looking to remove that section which is connected to the 3rd brake light inside the car. Im going in to get my windows tinted on tuesday and I want to make sure theres no chance they cut around it and instead will tint the entire window. I've looked everywhere and cant find any how to on it so does anyone know how I can remove that piece?
bigwayne3000 is offline
post #2 of 4 Old 01-10-2011, 10:14 AM Thread Starter
Bump, anyone?
post #3 of 4 Old 01-10-2011, 10:29 AM
POWERFREAK's Avatar
mmmm, give it a little more time...you posted it less than an hour ago.
POWERFREAK is offline
post #4 of 4 Old 01-10-2011, 11:08 AM
kc0cmj's Avatar
Preliminary Procedures
Remove the rear window panel trim. Refer to Rear Window Panel Trim Replacement.
Pull back the window panel acoustic trim filler in order to access the high mount stop lamp.
Disengage the high mount stop lamp electrical connector from the rear window trim panel.
Pull the high mount stop lamp from the rear window panel trim.
Here are instructions for rear window panel trim:
Disable SIR system. Refer to SIR Disabling and Enabling.
Remove quarter upper trim panel. Refer to Quarter Upper Trim Panel Replacement.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement.
Pull the release strap located in the center of the rear seat back cushion, folding the rear seat forward.
1
Rear Window Panel Trim Fastener (Qty: 4)
2
Rear Window Panel Trim Assembly
Procedure
When replacing the rear window panel trim assembly, transfer all necessary components.
Good Luck!!!
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
Human Verification
