DYNO TUNING SPECIALS AND RATES - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Southwest Members HI, CA, NV, UT, AZ, NM, CO
post #1 of 1 Old 09-29-2016, 03:32 PM Thread Starter
ModernCamaro.com Sponsor
Granatelli Sales's Avatar
Professional dyno tuning is the ONLY way to maximize your vehicle's horsepower and torque; And nobody dyno tunes better than Granatelli! Granatelli offers YOU the most advanced chassis dyno tuning center in the Southern California area. Granatelli features an 1800HP AWD Mustang inertia chassis dyno with full diagnostics, wideband O2 sensors, air / fuel ratio monitors and much more. We'll fine tune your air / fuel ratio for maximum power on pump gas with NO ENGINE KNOCK. Need installation? Granatelli is THE expert at installing turbos, superchargers, suspension, brakes, exhaust, and much more! We offer professional installations at our facility by ASE certified and Granatelli trained mechanics. Don't take chances with your hard earned dollars and valuable time...get your car or truck Tuned By Granatelli now!
Chassis Dyno Tuning
- Improves power & driveability on PUMP GAS!
- 1,800hp AWD Mustang inertia chassis dyno
- Wide Band O2 Sensor Tuning
- Air / Fuel Ratio Monitoring
- Exhaust Gas Temperature Monitoring
- Real Time Data Acquisition
- Variable Load Simulation
- OBD-II Diagnostics
- Custom ECM Programming
Installations
- Computer chips, flash tuners & modules
- Cold air intakes & colder thermostats
- Exhaust headers & cat-back exhausts
- Turbo, superchargers & nitrous
- Intake manifolds & throttle bodies
- Camshafts, heads & roller rocker arms
- Shifters, clutches, shift kits & converters
- Chassis, suspension & brakes
- Rear end gears & speedo calibration
- Gauges and custom gauge panels
- Engine oil & transmission oil coolers
Dyno and Dyno Tuning Rates:
- Two wheel drive, 3 pulls = $155
- Four wheel drive, 3 pulls = $175
- Naturally Aspirated Dyno tuning using customer supplied fuel injection system = $650
- Naturally Aspirated Dyno tuning using customer supplied fuel injection system with CAM = $700
- Forced Induction and Nitrous Dyno tuning using customer supplied fuel injection system = $750
- Forced Induction and Nitrous Dyno tuning using customer supplied fuel injection system with CAM = $800
- Carbureted applications = $600 and up . Please call for detailed quote.
- Naturally Aspirated Dyno tuning with GMS Supplied hand held tuner = $950
- Stand alone hand held tuner = $370
- Dyno rental $200 for the first hour $40 for ever 15 min after NO TIME LIMIT
If you have anymore questions or want to set up an appointment for an install or dyno tune, call us:
805-486-6684 OR PM me
Granatelli Sales is offline
Human Verification
