What do i need??? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
Go Back   ModernCamaro.com - 5th Generation Camaro Enthusiasts > 5th Generation Camaro - Technical Discussions > Tires, Wheels, Brakes & Suspension forum
Register Garage Photo Gallery FAQ Members List Calendar Advertise Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
Old 08-07-2011, 10:06 PM   #1
ddavis4035's Avatar
ddavis4035 is an unknown quantity at this point
What do i need???
Ok guys, i ran my first autocross this weekend with my car completely stock and absolutely loved it. immediately i knew i needed some work haha. As far as just suspension parts, other than springs and sway bars, what else would you recommend upgrading while im tearing everything apart? Any brand recommendations? Ive been looking at BMR, heard some good stuff about them and the price is right....
__________________
2011 Camaro 1LT RS. Summit White. Cyber Gray Metallic stripes. Heritage Grille. Stay tuned...more to come!!
ddavis4035 is offline
Old 08-08-2011, 09:36 AM   #2
hypurone is on a distinguished road
Springs and Sways will get you the most benefit. Coilovers would get you the added ride height adjustment benefit and allow corner balancing. You might want to look at the Pfadt stuff, their race bars are adjustable front and rear, with the front being tubular. All depends on your budget and how hardcore you wanna go...
__________________
2010 SIM 2SS/RS A6 SC - Born on 10/05/09 MyCamaroBuildInfo
"Something Wicked This Way Comes"
Old 08-08-2011, 09:52 AM   #3
2010_5thgen's Avatar
2010_5thgen will become famous soon enough
how stiff do you want the ride? bushings..... bmr is the cheapest and one of the best. if your goign to buy alot of stuff, try to get everythign from the same company. all their parts are tested together. so you know everything will work good. dont mix and match parts.
__________________
Looking for a driver for your team? Im your guy!
2010_5thgen is offline
Old 08-08-2011, 08:33 PM   #4
ddavis4035's Avatar
I definitely dont want to go crazy with it. This IS my daily driver, just a little track time on the weekends. But ill look a little further into the BMR stuff. Thanks for the input guys
__________________
Old 08-11-2011, 02:26 PM   #5
rudy@tirerack is on a distinguished road
1. Tires # 1
2. Start with basics. Alignment and tweaking air pressures.
3. Sways
4. If your serious coilovers but you can be very competitive with a good spring/damper setup.
rudy@tirerack is offline
Old 08-11-2011, 03:19 PM   #6
ddavis4035's Avatar
im thinking about gettin a new set of wheels and tires to only use on track days so i dont tear up the tires i drive on daily. Do you have a recommendation on what tire to go with? and should i keep the 20" diameter or go with something a little smaller to keep the rotating weight down? Its a v6 so i wont have to worry about brake clearance like the SS model. And as far as tire pressures, should i go with a higher pressure or lower pressure on road courses? Im very new to this so thanks for all the help
__________________
Old 08-15-2011, 11:47 AM   #7
BMR guy's Avatar
BMR guy is on a distinguished road
An 18" wheel and tire will definitely save some weight and make your suspension react quicker. There is also a lot more options in tires. If you are going to have a set of dedicated track wheels/tires I would use the Toyo R888's or Nitto NT01's. Generally speaking higher pressures work better if the wheel width is correct for the tire but they will always vary slightly depending on other factors. In other words there won't be a set pressure anyone can recommend for all Camaros.
Probably the best thing you can do to decrease your lap times and save your tires is a performance alignment. Adding more negative camber will wear tires a little quicker in the long run but will help save them at the track because they won't roll over as much and chew up the outside. This is also something to consider if you get a second set of track-only wheels/tires. A set of sticky tires and a good alignment will literally transform the car!
__________________
Brett
WWW.BMRSUSPENSION.COM
BMR guy is offline
Old 08-15-2011, 08:48 PM   #8
745RWHP, 660RWTQ
BLACK10's Avatar
BLACK10 is on a distinguished road
i def recommend BMR suspension.
__________________
ORDER BLACKOUT LENS TINT,BOWTIE COVERS AND SHIFTERS FROM
CHAUFFE PERFORMANCE.COM
FOLLOW US ON FACEBOOK
BLACK10 is offline
Old 08-15-2011, 11:12 PM   #9
Camaro Freak is on a distinguished road
+1
__________________
Old 08-17-2011, 09:59 AM   #10
Apex Chase is on a distinguished road
Sway bars and sub frame bushings are two of the biggest bang for your buck suspension upgrades you can make to the cars regardless of how you use it. For autoX use they are musts. Sway bars will help dial out under steer and body roll. Sub frame bushing upgrades will reduce or eliminate movement in the rear sub frame which will improve launch control and wheel hop and improve stability and control in the corners. BMR and Pfadt are my "go to" brands.
Apex Chase is offline
Sponsors
You may not post new threads
You may not post replies
SEO by vBSEO 3.5.2
©2006 - 2013 ModernCamaro.com
