2014 Engine Swap to a 2010 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 1 Old 04-06-2017, 08:52 PM Thread Starter
Hi all, new to the forum. I have a 2010 Camaro V6 6 speed manual base model. No mods everything original. I just had an engine failure at 89k... I have have an opportunity to change the engine from a 2014 (automatic) v6 salvaged camaro. Any help or ideas with the following questions would be appreciated.
Do you think the the engine swap will be an easy swap in regards to computer, wiring plugs, fitting, ect...
Would it be more beneficial to swap the out the complete engine and Manual transmission and replace it with the
engine and automatic transmission from the 2014?
Per the online research It looks like everything is the same. What do you think?
Thank you in advance for your feed back.
Jperez is offline
Human Verification
