Oil pan torque specs? - Page 2 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #11 of 15 Old 03-07-2011, 01:37 PM
A.J.'s Avatar
See this post: Oil leak at 2,000 miles There's a photo of the leak I had. Dealer did all kinds of things but it took replacing the oil pan to finally stop it.
Ordered 10-14-08 - Silver Ice Metallic/Leather 2SS/RS, 6 Spd, Sunroof, Polished Wheels. Build date: 04-17-09. Delivered: 04-29-09!
Ordered 10/29/11 - 2012 ZL1, Silver Ice Metallic, 6 Spd, Sunroof, Polished Wheels. Built on 05/17/12, deliverd on 05/30/12
A.J. is offline
post #12 of 15 Old 03-07-2011, 01:49 PM
kc0cmj's Avatar
Bullitin Search.
First question...
Oil Pan
Bolt - Block M8
25 Nm
18 lb ft
Bolt - Crankshaft Rear Oil Seal Housing M6
10 Nm
89 lb in
Windage Tray Bolt
10 Nm
89 lb in
Second comment..
This is the only bullitin that popped up..
#05-06-01-034L: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L-Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Jul 23, 2010)
Subject: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure)
Models: 2004-2007 Buick Rainier
2008-2009 Buick LaCrosse Super, Allure Super (Canada Only)
2005-2011 Cadillac CTS-V
2007-2011 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2009 Chevrolet TrailBlazer
2003-2011 Chevrolet Corvette
2004-2006 Chevrolet SSR
2005-2011 Chevrolet Silverado, Silverado SS
2006-2007 Chevrolet Monte Carlo SS
2006-2009 Chevrolet TrailBlazer SS, Impala SS
2007-2011 Chevrolet Avalanche, Suburban, Tahoe
2009-2010 Chevrolet Colorado Pickup
2010-2011Chevrolet Camaro
2003-2009 GMC Envoy
2003-2011 GMC Sierra
2004-2005 GMC Envoy XUV
2007-2011 GMC Yukon XL, Yukon Denali, Yukon XL Denali
2009-2011 GMC Canyon
2004-2006 Pontiac GTO
2005-2008 Pontiac Grand Prix GXP
2008-2009 Pontiac G8 GT
2009 Pontiac G8 GXP
2005-2009 Saab 9-7X 5.3i
2008-2009 Saab 9-7X Aero
2003-2010 HUMMER H2
2006-2010 HUMMER H3
with 5.3L, 5.7L, 6.0L, 6.2L, 7.0L VORTEC GEN III or GEN IV V8 Engine (All Aluminum Block) (RPOs L33, LC9, LH6, LH8, LH9, LM4, LS4, LS1, LS6, L76, L77, LFA, LZ1, LS2, L92, L94, L99, L9H, LS3, LS9, LSA, LS7)
This bulletin is being revised to add the 2011 modelyear and update the Warranty Information for the Corvette. Please discard Corporate Bulletin Number 05-06-01-034K (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on an engine oil leak.
Cause
Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only.
Correction
Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect the engine block and engine rear cover for porosity on the mating surfaces.
If porosity is found on the engine rear cover (see illustration below), replace the engine rear cover assembly, GM P/N 12633579.
If porosity is found on the engine block, use the following procedure to apply RTV to repair the engine block porosity.
The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. Refer to the picture below. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity. Refer to the illustration below.
Important: Clean any residual oil from the block and cover before applying the sealant in the next step.
Wipe a small amount of RTV, P/N 12378521 (in Canada, use P/N 88901148), onto the surface using a plastic scraper to fill the porosity.
Remove any excess RTV material, especially from inside the high pressure oil passage. Refer to #1 in the above illustration.
The joint may be closed immediately after applying the RTV. Total joint time after the RTV has been applied must be under 20 minutes.
Important: Refer to Engine Rear Cover Replacement in SI and follow the tightening specifications and sequence.
Reinstall the engine rear cover using a new gasket and a new crankshaft rear main seal. Refer to Engine Rear Cover Replacement in SI.
Parts Information
Important: For Saab (U.S.) only, use P/N 88861206 - Engine Oil Dye (U.S.) or equivalent.
Part Number
Description
Qty
12574293
Gasket - Crankshaft Rear Oil Seal Housing
1
89060436
Seal, Crankshaft Rear Main
1
12378521
(in Canada, use 88901148)
Sealant
1
88861206
(in Canada, use 88861259)
Dye, Engine Oil
1
12633579
Housing Asm - Rear Cover
1
Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7510*
Oil Leak -- Rear Cover Area -- Porosity Repair
Colorado/Canyon
5.5 hrs
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
8.0 hrs
6.7 hrs
SSR
5.4 hrs
TrailBlazer/Envoy/Rainier/Saab 9-7X /Saab 9-7X Aero, H3
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
4.1 hrs
4.3 hrs
G8/Camaro
4.0 hrs
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #13 of 15 Old 03-07-2011, 03:13 PM Thread Starter
ffej0127's Avatar
that looks like the same leak, plus i have a little wetness on the top of the pan around the 10mm bolts witch makes me think the pan gasket is leaking a little too.
2SS..IO Interior M6 Black Rally Stripes Borla Mufflers Diablo Tuned 20% Tints Vararam ram air, Eibach front and rear sway bars, BMR trailing arms, BMR toe rods, BMR lower control arms, BMR strut tower brace, SLP Long tubes with high flow cats Granetelli cross drilled and slotted rotors BBK 95mm Throttle body Eibach coil overs, BMR Adjustable Front and Rear Sway Bar End Links Bravado 20" Rims with Eagle F1 305/35/20 in the Rear and 275/35/20 front
ffej0127 is offline
post #14 of 15 Old 03-08-2011, 12:14 AM
Move Over's Avatar
[QUOTE=kc0cmj;312291]First question...
Oil Pan
Bolt - Block M8
25 Nm
18 lb ft
10 Nm
89 lb in
Windage Tray Bolt
10 Nm
89 lb in
Second comment..
2003-2009 GMC Envoy
2009 Pontiac G8 GXP
2003-2010 HUMMER H2
2006-2010 HUMMER H3
Condition
Cause
Correction
Parts Information
Part Number
Description
Qty
12574293
1
89060436
1
12378521
Sealant
1
88861206
Dye, Engine Oil
1
12633579
1
Labor Operation
Description
Labor Time
J7510*
Colorado/Canyon
5.5 hrs
CTS-V
5.5 hrs
Corvette
- M/T
- A/T
8.0 hrs
6.7 hrs
SSR
5.4 hrs
- 2WD
- 4WD
5.7 hrs
6.5 hrs
GTO
- M/T
- A/T
4.1 hrs
4.3 hrs
G8/Camaro
4.0 hrs[/QU
This is what they did to my car.
Move Over is offline
post #15 of 15 Old 03-11-2011, 05:28 PM Thread Starter
ffej0127's Avatar
So I got my car back today and what they did is put a die into the oil to see where excactly is is leaking from.
I have to drive 400-500 miles then bring it back in for a black light test to find the leak.
ffej0127 is offline
Human Verification
