AAC's 1969 Pro Touring Resto-Mod Camaro Build - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 13 Old 06-06-2011, 01:18 PM Thread Starter
The Lighting Specialists
AACstyle's Avatar
Thumbs up AAC's 1969 Pro Touring Resto-Mod Camaro Build
We have been swamped lately so I have not been able to post a complete build thread of this project but figured I would start the thread and update it as we find time.
Ok first the car started as an all original '69 X44 body, we did not have possession of the car at this time but here is how it looked:
Body:
Smoothed Firewall:
Frame:
Coilovers/ Fuel Cell:
Last but not least... the powerplant!
Here is a quick mod run-down:
DSE SMOOTH FIREWALL
DSE MINI TUB KIT
DSE SUBFRAME CONNECTORS
GOODMARK STEEL COWL HOOD
POWER WINDOWS
ELECTRIC TRUNK LATCH
LINEX ENTIRE UNDERCARRIAGE
SPEED-TECH UPPER CONTROL ARMS
SPEED-TECH LOWER CONTROL ARMS
KDW QA-1 COIL OVERS
ENERGY SUSPENSIONS BUSHINGS
ENERGY SUSPENSIONS END LINKS
ENERGY SUSPENSIONS MOTOR MOUNTS
ENERGY SUSPENSIONS TRANS MOUNT
SPEED-TECH SOLID ALUMINUM BODY MOUNTS
BODY MOUNTS REINFORCED WITH WELD-IN 1/4” PLATES
PRODIGY CUSTOMS CANTED 4 LINK SUSPENSION
CUSTOM PRODIGY COILOVER SPRINGS
LATE MODEL POWER STEERING GEARBOX
DSE CONVERSION FITTINGS
EARLS BRAIDED STAINLESS POWER STEERING HOSES
NEW LS6 POWER STEERING PUMP WITH DSE OUTLET
SPEED-TECH ANODIZED BRAKE BRACKETS
Z06 CALIPERS AND ABUTEMENTS
EBC REDSTUFF PADS
EBC SLOTTED AND DIMPLED ROTORS
BRAIDED BRAKE LINES INSTALLED
MOSER 9 INCH REAR AXLE
LATE MODEL CAMARO BACKING PLATES
LATE MODEL CAMARO PARKING MECHANISM
EARLS BRAIDED CENTER LINE WITH CUSTOM AXLE LINES
MODIFIED LATE MODEL CAMARO BRAKE BOOSTER
WILLWOOD ADJUSTABLE PROP VALVE
PRODIGY CUSTOMS / RICK TANKS STAINLESS STEEL FUEL CELL
INLET TAIL PANEL CUSTOMIZED TO FIT FLUSH MOUNT GAS CAP
INTANK BOSCH "044" FUEL PUMP
PCM CONTROLLED LEVEL ASSEMBLY
AEROMOTIVE FITTINGS AND LINES 8AN FEED/6AN RETURN
AEROMOTIVE INLINE FUEL FILTER
AEROMOTIVE FUEL PRESSURE REGULATOR
AEROMOTIVE FUEL PRESSURE GAUGE
AEROMOTIVE FUEL RAILS/CROSSOVER LINE
LS7 DELCO FUEL INJECTORS
NEW GM LQ9 BLOCK
EAGLE FORGED 4 INCH STROKE CRANKSHAFT
EAGLE FORGED RODS
ARP 2000 ROD BOLTS
MANLEY FORGED PISTONS
LIGHTWEIGHT PINS
SPIROLOCKS
COVETTE Z06 BALANCER
ARP MAIN STUDS
ARP BALANCER BOLT
ARP HEAD STUDS
ARP STAINLESS HEADER STUDS
L92 RECTANGULAR PORT CYLINDER HEADS
COMP CAMS 26918 VALVE SPRINGS
TITANIUM RETAINERS
COMP CAMS PUSHRODS
COMP CAMS R SERIES LIFTERS
COMP CAMS CUSTOM GRIND CAM 580, 224, 115
COMP CAMS HEX-ADJUST TIMING CHAIN SET
LS2 TIMING CHAIN DAMPENER SYSTEM
LS6 HIGH VOLUME OIL PUMP
JMZ SWAP OIL PAN AND PICKUP TUBE
LS7 ROCKER ARMS
LS3 INTAKE MANIFOLD
LS3 90MM THROTTLE BODY
SPEARTECH PERFORMANCE ENGINE/TRANS HARNESS
SPEARTECH PERFORMANCE CUSTOM ECM AND TUNE
MSD PLUG WIRES
NGK PLUGS
GM PERFORMANCE ACCESSORY DRIVE
LS6 WATER PUMP
LS6 ALTERNATOR
KWIK PERFORMANCE COMPRESSOR MOUNT
SANDEN COMPRESSOR
BE-COOL DUAL FAN ASSEMBLY (PCM CONTROLLED)
BE-COOL ALUMINUM RADIATOR
BE-COOL AC CONDENSER
CUSTOM RADIATOR/CONDENSER MOUNTS
5 WIRE MASS AIR FLOW SENSOR
HOOKER CERAMIC COATED LONG TUBE HEADERS
HOOKER LS1 SWAP MOUNT BRACKETS
ENERGY SUSPENSION MOUNTS
MAGNAFLOW 3 INCH XPIPE
PRODIGY CUSTOMS TAILPIPES FOR PRODIGY BAR SUSPENSION
4L60E TRANSMISSION UPGRADED INTERNALS
TCI MASTER KIT WITH RED CLUTCHES
TCI SERVO'S INSTALLED
TCI 3200 STALL CONVERTOR
TRANS-GO SHIFT KIT
CUSTOM COOLER LINES
CUSTOM TRANS COOLER
MOSER 9" REAR END
LS1 AXLE ENDS
CURRIE 9" NODULAR CENTER SECTION
CURRIE BIG BEARING PINION SUPPORT
ARP STUDS
RICHMOND 3.70 GEARS
ARP RING GEAR BOLTS
AUBURN LIMITED SLIP
33 SPLINE MOSER FORGED AXLES (CUSTOM LENGTH)
AUTOMETER GAUGES
FLAMING RIVER TILT STEERING COLUMN
FLAMING RIVER RAG JOINT
FLAMING RIVER CRUISE CONTROL STALK (PCM CONTROLLED)
NEW CUT PILE BLACK CARPET
ELECTRIC CAMARO SS FRONT SEATS
AMERICAN AUTOWIRE FUSEBLOCK / COMPLETE HARNESS
ELECTRIC LIFE POWER DOOR LOCK KIT
ELECTRIC LIFE KEYLESS ENTRY W/ POWER TRUNK
Fast Forward to Camaro Fest 2011,
LS3 Engine cover custom painted & Installed:
Test fitting new console with custom aluma-grain hydrographics and LED illumination:
Update:
HUGE thanks to all our friends at Metra for supplying us with their Top-of-the-Line audio components for this build! This car is going to sound simply amazing!
Update:
Hmmm... need to get creative to fit this iPad into this new console!
Update:
Teaser Pic of the new nearly-completed sound system (this is what 3 months worth of work looks like):
Update:
The new sound system came out so nice we are doing a photoshoot
Update:
Of course you can't have a badass pro-touring Camaro without a custom set of wheels. Bismark and USW really came through for us with these custom USW Forged wheels!
AACstyle is offline
post #2 of 13 Old 06-06-2011, 01:18 PM Thread Starter
AACstyle's Avatar
*Updated Shots*
Here is another teaser from the soon to be released ORACLE Camaro Photoshoot:
Interior Shot:
Yes, that is an iPad integrated in the console. Why? Controls the stereo, navigation, and on-board web browsing
Update- New Pics!
Motor:
Sound:
Custom Kick Panels:
One of my favorite mods on this entire car is the "hideaway" sidemarkers!
We really wanted to incorporate some of our own products into this build and this was a great way to do it
AACstyle is offline
post #3 of 13 Old 06-06-2011, 01:19 PM Thread Starter
AACstyle's Avatar
Glamor Shot:
AACstyle is offline
post #4 of 13 Old 06-06-2011, 01:19 PM Thread Starter
AACstyle's Avatar
We used the ORACLE ColorSHIFT LED Strip to illuminate the engine bay which allows us to change colors. Good option if you do not want to commit to one color
AACstyle is offline
post #5 of 13 Old 06-06-2011, 03:26 PM
That is one sweeeeeeeeeeeeeeeeeeet ride nice job guys
post #6 of 13 Old 06-06-2011, 03:45 PM Thread Starter
AACstyle's Avatar
Thanks, will be posting more pics and videos soon
AACstyle is offline
post #7 of 13 Old 07-21-2011, 05:58 PM Thread Starter
AACstyle's Avatar
Interior Shot:
AACstyle is offline
post #8 of 13 Old 07-21-2011, 06:14 PM
brandonppr's Avatar
Very nice build
brandonppr is offline
post #9 of 13 Old 07-21-2011, 08:24 PM
Wow!!! I'm speechless!!
post #10 of 13 Old 02-28-2012, 09:45 AM Thread Starter
AACstyle's Avatar
Hate to see it go but we are moving on to the NEXT project!
1969 Chevrolet Camaro for Sale - 1136138 - duPontREGISTRY.com
AACstyle is offline
