Nitto 555R ? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 10-17-2008, 10:02 AM Thread Starter
drc
Nitto 555R ?
I'm going to run my '68 at the drags tonight and want to know what most people run their tire pressure at on a set of 555R's?
drc is offline
post #2 of 7 Old 10-17-2008, 12:28 PM
Moderator
USA1Camaro's Avatar
Too bad you don't have a little more time to do some testing. You might have to do some experimenting. I usually start out at around 25psi on street tires and adjust from there. It takes time to find out what works for your set-up.
Have a friend video your passes. Post them up.
USA1Camaro is offline
post #3 of 7 Old 10-18-2008, 09:09 AM Thread Starter
drc
I started at 28 which is what I run on the street and it actually seemed to hook up pretty good. Then I went to 24 and it broke loose a little so I went to 18 thinking ok they are going to be soft and should hook great but, on that pass, I broke them totally loose so I'm baffled. I wasn't running much fuel at all... probably only 4 gallons on the first pass and then down from there plus I might have been stalling up a little more each time but not by much. I probably stalled at about 2000 on the last past. One thing I noticed was during my burnout the tires wouldn't produce smoke hardly at all. Are you supposed to heat these tires up or not? I just couldn't believe how bad I broke them loose when they were at 18. I wanted to keep dropping them until the rearend started feeling loose on the big end and then add just enough to take that away.
drc is offline
post #4 of 7 Old 10-19-2008, 02:31 PM
Moderator
USA1Camaro's Avatar
Street radials: Go around the water just clean them off. IMO no need to do a long smokey burn-out.
What were you 60' and 1/4 times for these passes?
post #5 of 7 Old 10-19-2008, 03:22 PM Thread Starter
drc
On my first and best run I had a 60' time of 1.831 a 330' of 5.405 an 1/8 of [email protected] a 1000' of 11.035 and a 1/4 of [email protected] I had a shift module of 5800 in during this pass.
On my next pass I had a 60' time of 1.854 a 330' of 5.414 an 1/8 of [email protected] a 1000' of 11.046 and a 1/4 of [email protected] I had a shif module of 5400 in during this pass.
I did notice the tires chirping more on the second pass but it looks like I was making up time by shifting a little earlier but then what gets me is where I lost time from the 1/8 to 1000' mark because I was on pace to run a quicker 1/4 even though my 60' was slower by .023.
Then my last past I could really tell I broke the tires loose and my 60' was 2.189.
I wish I could come across some of my old time sheets to see what I used to run a 60' time in when I know I wasn't spinning the tires at all.
drc is offline
post #6 of 7 Old 10-19-2008, 03:31 PM Thread Starter
drc
I am right in thinking to run my tires with as little pressure as possible without getting loose on the big end right?
drc is offline
post #7 of 7 Old 10-19-2008, 09:12 PM
tazjetman's Avatar
this makes me think....
Facebook has sucked me into Farmtown.
What can I say I love virtual plowing.
tazjetman is offline
