What the **** is this? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 15 Old 05-23-2009, 02:00 PM Thread Starter
HBZ28's Avatar
Looks like a sensor... it was just hanging there by the throttle body. Car runs good, drives fine.
HBZ28 is offline
post #2 of 15 Old 05-23-2009, 02:49 PM
SS-Eric
SS-Eric's Avatar
I think that's the gaphinator plug... It controls the binker fluid level.
SS-ERIC
SS-Eric is offline
post #3 of 15 Old 05-23-2009, 03:01 PM Thread Starter
HBZ28's Avatar
Okay, why does everyone do that to me...? I know I'm pretty new with motors, but seriously?
Well I also discovered why my car can't be started without having the timing cable being plugged in and has no top end power. The shop that had it last installed a 350tb unit on my 305 motor. They'll be fixing that for free, I'll make sure of that.
Also, I found all this oil under the car, too.
HBZ28 is offline
post #4 of 15 Old 05-23-2009, 03:05 PM
sdoomxz's Avatar
Yep thats Oil
'Winning'
sdoomxz is offline
post #5 of 15 Old 05-23-2009, 03:12 PM Thread Starter
HBZ28's Avatar
And... my oil inside the car reads full and it's not milky... what's the problem?
HBZ28 is offline
post #6 of 15 Old 05-23-2009, 03:19 PM
Racer505's Avatar
I think that is the control for the flux capacitor. You might wanna go to Auto Zone and get a new one you don't wanna get up to 88 mph with out that
to Err is human, to blame someone else shows good managemt skills
06 Ponitac g6 gt
2010 Ram2500 Megacab Cummins
2010 Suburban LTZ
2012 Camaro 45th Aniv. Vert (Very shortley)
Racer505 is offline
post #7 of 15 Old 05-23-2009, 03:57 PM
Thirdgenrallysport's Avatar
get a chilton manual and look at the wiring diagrams.
~Travis~
90 RS-383HSR, T56, NX wet kit
01 LB7 Chevy 2500 4x4. Programmer, 3" lift on 35s
Thirdgenrallysport is offline
post #8 of 15 Old 05-23-2009, 05:50 PM Thread Starter
HBZ28's Avatar
Okay. Got the book already, I'll check it out. Now what about the oil?
HBZ28 is offline
post #9 of 15 Old 05-23-2009, 06:11 PM
check the obvious first, drain plug, oil cap, dipstick, oil pan gasket leak, valve cover leak. you wont until you start getting in there and look around.
Got Me SOM is offline
post #10 of 15 Old 05-23-2009, 07:51 PM
Racer505's Avatar
The most common leaks are the valve cover gaskets, oil pan, and the rear main seal. Depending what year motor that is, it could have the 2 piece rear seal, and those dry out, crack, and start leaking with age. Same with the valve cover gasket, and oil pan gasket. If it's the rear main or the oil pan, i am pretty sure you gotta pull the motor on ur car.
Does it leak while just sitting there, or while it is running, or while it is warm after you drove it? And how much oil does it go though, If your putting a quart every time you put gas in, not good. If you goin though a half quart to a quart, ever oil change it ain't that bad.
06 Ponitac g6 gt
2010 Suburban LTZ
Racer505 is offline
