Starting problem - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 09-28-2009, 08:47 AM Thread Starter
HBZ28's Avatar
Starting problem
Long time since I posted here! I'm having a bit of an issue occasionally with start up on my '92 RS. The car will turn over, but shuts off in a few seconds, and then just keeps turning over when you try to start it again. I have to pop the hood and have some one choke the throttle and then it starts right up and runs fine... this only seems to happen occasionally, and mostly just when I'm in Edgerton with my girlfriend... WTF!? I don't know what's going on. Any idea's?
HBZ28 is offline
post #2 of 5 Old 09-28-2009, 12:27 PM
89RS's Avatar
Sticktion in the IAC. Happens to me every now and then. Just give it gas while you crank and it'll fire up.
Project: 89 RS => AX/RR
89RS is offline
post #3 of 5 Old 09-29-2009, 07:31 AM Thread Starter
HBZ28's Avatar
I had heard a suggestion to adjust the needles on the tbi, not sure. It's getting annoying lol. And my girlfriend is affraid it won't start sometimes lol.
HBZ28 is offline
post #4 of 5 Old 09-29-2009, 08:47 AM
89RS's Avatar
The only adjustment I've ever made to my TBI is with my right foot. If you push the pedal hard enough, the IAC will finally get unstuck and open up in the right direction. You don't need tools to fix this problem.
Works every time for me.
89RS is offline
post #5 of 5 Old 09-29-2009, 09:21 PM
Aaron, you can remove that IAC valve and clean it, pretty simple procedure. The info is on thirdgen somewhere. I have had that issue many times in my 3rd gens, we just did that fix on bills!
Tim
1997 30th Anniversary Z28-LS1 Powered
Anniversaryz28 is offline
