2010 SS engine in a thirdgen - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 20 Old 08-01-2010, 05:58 PM Thread Starter
sk8r_fer_life's Avatar
hey guys does anyone know if there is a Kmember setup to do this swap? and what else would I need?
1990 CAMARO RS - 2" Flowmaster
Best time - 16.63s @ 83mph on street tires
sk8r_fer_life is offline
post #2 of 20 Old 08-01-2010, 06:29 PM
89RS's Avatar
Thirdgen.org has several threads on this subject. Yes there are aftermarket K-members from BMR & Spohn for this, but on TGO they also document the mods you can make to a stock K-member to get it to work.
LS3's aren't cheap though. The cheapest all-in-one package out there is the E-Rod package and its $8400 for the engine, headers, harness & ECU. It'll be another $600 for the K-member and thats assuming you can salvage the accessories and what not from an LS1 4th gen. Assuming you can't and that the E-Rod supplied headers don't fit, its almost $2k for LSx swap headers for a third gen and a GMPP LS accessory drive kit.
There are alot of costs to look at before doing this kind of swap.
Project: 89 RS => AX/RR
89RS is offline
post #3 of 20 Old 08-01-2010, 10:29 PM
WRAITHSS's Avatar
I have a BMR in my 3rd gen. I have seen both and went with bmr.
Chance Favors The Prepared Mind!
Originally Posted by el ess X View Post
Look at it this way, if you have "Camaro" written on your car somewhere, you're already starting with a great platform!!
WRAITHSS is offline
post #4 of 20 Old 08-01-2010, 10:49 PM
80s_Adam's Avatar
Wow this is awesome, anybody have them complete yet?
80s_Adam is offline
post #5 of 20 Old 08-01-2010, 11:08 PM
WRAITHSS's Avatar
What do you mean complete?
WRAITHSS is offline
post #6 of 20 Old 08-03-2010, 09:32 AM
Like everyone said I can get you all the stuff you need to bolt the LS3 motor into the car. Other then that you are going to need quite a few other things like engine harness, computer, and some fuel system parts. That pretty much covers the big parts needed. Use Thirdgen.org to help you out, there have been quite a few guys there who have done the LS swap on their 3rd gens.
BMR Sales is offline
post #7 of 20 Old 08-03-2010, 11:26 AM
Any LS based engine K-Member will work. The LS3 isn't special. I don't personally care for their drive by wire system for swaps. LS1s are a dime a dozen, and 6.0L LS based truck blocks are super easy to find.
Devryn is offline
post #8 of 20 Old 08-03-2010, 03:01 PM
Supporter of common sense
OverAnxious's Avatar
Should be like any other LS swap, plenty of kits/parts are out there. L99 may be a little cheaper
OverAnxious is offline
post #9 of 20 Old 08-03-2010, 04:01 PM
89RS's Avatar
As far as getting a transmission to fit, you can buy a crank adapter and LSx swap flexplate for an auto transmission. But the harness, ECU, and other assorted items aren't easy to find. The L99 isn't a crate engine for a reason. Not many people out there are looking at using AFM in an LSx swap.
89RS is offline
post #10 of 20 Old 08-03-2010, 07:46 PM
demonspeed's Avatar
I don't see the point of doing the LS3 other than the novelty of saying you swapped a LS3. There are much better builds that you could do with a LS-based engine considering the amount of work that's required to do the swap. Couple that with the fact of the price of a LS3 crate -- you could have a wild setup.
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
