misfireing. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 01-07-2007, 07:31 PM Thread Starter
misfireing.
ok my car was misfirering and i did a tun-up changing the plugs and wires. and the misfire went away. and now is misfiring anytime i use medium or more throttle. i have p0306 code set each time and its getting annoying.
and to today i noticed that i have orange spots on my rear bumper, i used the window squege to get it off but found that odd.
anyone had this problem or know what it is?
thanks for any help.
thegodofgodes is offline
post #2 of 7 Old 01-07-2007, 07:39 PM
What year car, what engine? We can't really help you unless you can give us more detail.
Chris 96 WS6 is offline
post #3 of 7 Old 01-07-2007, 10:19 PM
54inches's Avatar
You have a studdering problem too!
JK!
54inches is offline
post #4 of 7 Old 01-08-2007, 01:28 PM
sounds like an air/fuel problem. sounds like it may be leaning itself out
fbodygrad is offline
post #5 of 7 Old 01-09-2007, 07:13 AM Thread Starter
1996 3.6 v6 with automatic.
its mostly when im as low rpm and try to pass, around 1500-2100 rpm after that is seams to go away.
also has anyone had to replace a head gasket before?
post #6 of 7 Old 01-09-2007, 08:17 AM
OctaneZ28's Avatar
P0306 = Cylinder 6 Misfire
Might be fuel injectors, try using a fuel system cleaner.
On my 96 V6, I had similar hesitations, but never set a SES light.
However I ended up having to replace 4 injectors.
OctaneZ28 is offline
post #7 of 7 Old 01-11-2007, 02:18 PM
3.6? wats it in?
