AC is Out...blew something - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 3 Old 05-31-2009, 03:27 PM Thread Starter
I got a 95 z28 my ac went out the other day... went to recharge it and found I have a leak, it was right behind the compressor... all I had to do was torque down that 1 lone bolt behind compressor(VERY Hard to get to)... a few days later the same problem shows itself again... this time I re torque the bolt, the leaking noises goes away, a sec later seem to have blown whatever gasket it has in there... from right behind the compressor where the A/C lines enter the compressor... how do I fix this problem... can I buy that gasket...any ideas fellas
95 z28 is offline
post #2 of 3 Old 05-31-2009, 04:26 PM
LorcinLS1's Avatar
They usually have an O ring in there. The last time I bought an oring it came as a set with different sizes.
LorcinLS1 is offline
post #3 of 3 Old 07-17-2009, 12:07 PM Thread Starter
Im buying a venturi pump for my a/c as I have just repair the
compressor (stripped the threads on the compressor that holds the ac lines to the back of it)... but now I have to vacum out the ac system ... does the vacum also suck out all the oil in the compressor and dryer or JUST the moisture???..thanks in advance! .... if anyone needs to know the thread size to a 1995 camaro compressor to ac line bolt... its M10 X 1.5 ...I want through hell to find that out
95 z28 is offline
