Need some more help guys - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 01-16-2010, 09:43 PM Thread Starter
MaroMan1989's Avatar
Hey everyone. Got another issue I would really like some help with. My fourth gen, 3.4 L V-6, has had some overheating issues. I took it to my mechanic and he said it might be an issue with radiator. Turns out the people I had bought the car from had a radiator leak and used, what I'm guessing, Bars stop leak in it to try and fix it. He replaced the radiator and flushed the cooling system. I went and got my car today and it ran no problems, no overheating. I was driving it for a little while, when out of the blue, it began to overheat again. The service engine soon light even went off. I parked it and let it rest for a little while and when I restarted it the light was off and it didnt overheat until about 20 minutes later. Any ideas.
R.I.P. Michael Jackson, King of Pop. You shaped music into everything it has become. Sing for the angels now.
MaroMan1989 is offline
post #2 of 10 Old 01-16-2010, 09:46 PM
POWERFREAK's Avatar
could be some air stuck in the system...need to purge it. Run it w/ the radiator cap off...let it heat up, air should burp out. Top it off w/ coolant or water...you should be good to go. If it's still a problem, the thermostat could be sticking.
POWERFREAK is offline
post #3 of 10 Old 01-16-2010, 09:48 PM Thread Starter
Okay, because it seemed to be running good, but when I see it redlining, I'm inclined to give it a rest. My mechanic told me that it still had air in the system.
post #4 of 10 Old 01-16-2010, 09:49 PM
POWERFREAK's Avatar
mmmm....yeah! and crank the heat, that will help cool it off a little.
sounds like a smart man although he SHOULD have purged it.
post #5 of 10 Old 01-16-2010, 09:55 PM Thread Starter
Heat isn't working right, I think the heater core may be up. Could that have something to do with it? And when you say run it with the cap off, do you mean to take the cap off first then start it? Because you already know what happens when the cap is taken off with the engine running or just turned off. I really don't like burns too much. lol
post #6 of 10 Old 01-17-2010, 06:35 AM
POWERFREAK's Avatar
If your heat isn't working right (but the fan does blow), sounds like your thermostat could be acting up....I would have swapped it when everything was drained.
As for purging...with the engine COLD, take off the cap...let it run and heat up to operating temp, when the thermostat opens (if it's working), air will "burp" out.
post #7 of 10 Old 01-17-2010, 08:15 AM
demonspeed's Avatar
I don't think a plugged heater core would cause anything to overheat. The coolant would just bypass the core.
I also don't believe that the stop leak would cause the car to overheat. I used it in my 89 when the heater started to leak, and it sealed the leak perfectly without causing anything to overheat.
I would investigate the thermostat, and also make sure your fan(s) are turning on.
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
post #8 of 10 Old 01-17-2010, 08:58 AM
You need to have your tech check for leaking head gaskets. They can fail in a way that allows exhaust gases to enter the cooling jackets and cause overheating and usually over-pressurization. There is a tool that uses a chemical and plugs into the radiator filler neck that detects exhaust gases. It looks like a bong! The one I had started out blue in color and would go green when gases were detected....
Good luck.
post #9 of 10 Old 01-17-2010, 11:15 PM
Moderator
slims00ls1z28's Avatar
Sounds like it needs to be purged. Air trapped under the thermostat which will not open/close it like normal (air can't push the spring completely). I can't remember it the v6's had a valve in the thermostat housing but you can do it from the temp sender on the driver side head. It will be under the thermostat (not location wise as it's located on the side of the head ) and should let all the air out under the thermostat. Start it, let it get warm. Then slowly loosen it to let out the steam while a buddy keeps the engine running at 2000 rpm's. Do this till nothing but coolant comes out. Had to do this on a couple V6 Camaro's. Air pockets are a PITA and have symptoms resembling alot of different other problems. Undoing the radiator cap will not release the air as it gets trapped under the thermostat.
If the thermostat wasn't changed when it was drained there's also a probable co-culprit like demonspeed mentioned. They are notorious for conking out when the system gets drained and I too would have changed it if I drained the system. I'd change the thermostat then do the bleed like I mentioned first. If the problem still persists then go with the above as some of the passages may have become clogged with the stop leak mechanic in a bottle crap. Start small and cheap before you go into the bigger more expensive junk.
slims00ls1z28 is offline
post #10 of 10 Old 01-19-2010, 01:19 PM
WRAITHSS's Avatar
Sounds like you have all the answers you need here.. Good Luck.
Chance Favors The Prepared Mind!
Originally Posted by el ess X View Post
Look at it this way, if you have "Camaro" written on your car somewhere, you're already starting with a great platform!!
WRAITHSS is offline
