Power wire wiring question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 09-19-2007, 09:34 PM Thread Starter
brandonppr's Avatar
Is it ok to run a power wire from the alternator to the starter then from the starter to the fuse box then from the fuse box to the battery?
I moved the fuse box to inside the car and I am trying to keep wiring at a minimum, but I wanted to make sure it is ok to do it that way.
It seems like it would be fine as long as there all positives and all hooked together at some point right?
brandonppr is offline
post #2 of 6 Old 09-19-2007, 09:35 PM
OctaneZ28's Avatar
In theory it sounds ok, but I am a wiring NOOB so I can't make a legitimate call one way or another on that lol.
OctaneZ28 is offline
post #3 of 6 Old 09-20-2007, 01:04 PM
Moderator
slims00ls1z28's Avatar
Ya, should be fine.
slims00ls1z28 is offline
post #4 of 6 Old 09-20-2007, 01:23 PM Thread Starter
brandonppr's Avatar
I was planning on firing this thing up friday but I guess I won't be. The TB was the last thing I was waiting on and it was supposed to be here friday but it has been delayed till monday. I guess I can do some other things on it till then, but I have been wanting to hear it run so bad
post #5 of 6 Old 09-21-2007, 07:21 AM
Moderator
I know what you mean. It will be a while before I can hear mine now :'(
post #6 of 6 Old 09-21-2007, 11:36 AM
CamaroCliff's Avatar
put my billet alt bracket on today, if im lucky it will solve my belt throwing problem. last week i tried an underdrive, deep groove pully. it got better for a while, but then still threw a belt, overheated and cracked a radiator tank. with the new bracket, it will be mounted correctly and should be able to keep a belt on. if not i will have to do a serpentine setup. i hear there is a cog drive for crank,waterpump,alt with a vbelt for ps. ill let you know when im driving it again.
1986 Camaro Berlinetta (originally)-now a nitrous breathing 383 stroker
1992 Camaro RS - pretty much stock (only to keep its 25th anniversary edition book value)
all the other Camaros were sold
CamaroCliff is offline
