auto tranmission issues. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 05-04-2011, 02:09 PM Thread Starter
I just bought a 94 camaro z28 with a automatic tranny. One the way home it was going good. but the last few days it wont shift unless i force the shift with the gas pedal. it hits all the gears when i force shift it. the tranny was rebuilt in February. someone told me it could be a cable but idk figured id see what u guys have to say. so any information would be great.
vwright90 is offline
post #2 of 7 Old 05-04-2011, 02:11 PM
Did they still have vacuum modulators then? I think the 94s were still rockin the 700R4 and not the 4L60E so it should have a vacuum modulator. That COULD be your problem.
Devryn is offline
post #3 of 7 Old 05-04-2011, 02:19 PM Thread Starter
i believe it is a 4L60E. idk much about trannys.
post #4 of 7 Old 05-04-2011, 02:28 PM
It is a 4L60E. Hmmm...Solenoid maybe? If you're sure it's not the actual transmission since it was just rebuilt. Cable doesn't make sense on a 4L60E either.
Out of curiousity, have you check the "hot" fluid level?
Devryn is offline
post #5 of 7 Old 05-04-2011, 02:33 PM Thread Starter
no i havent. might be a good place to start though. ill check it as soon as i get a chance too.
post #6 of 7 Old 05-04-2011, 03:45 PM
SC2150's Avatar
There are several shift solinoides in the 4L60E and any sticking can be an issue. If it is a 700R4 the detent cable out of proper adjustment will cause problems.
SC2150 is offline
post #7 of 7 Old 05-08-2011, 06:33 AM
Any luck identifying the issue?
Devryn is offline
