Clutch grind - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 10-20-2007, 06:35 PM Thread Starter
Clutch grind
Hi all,
I just bought a 1996 z28. It has a few problems but all something i can fix.
One of the problems is with the clutch (hence the title). When the clutch is pushed to the floor it will make an odd grinding-type noise, but not gear grind.. Has anyone come across this before?
Also, while the transmission is in reverse, you must hold the shifter in reverse or it will pop out of gear.. Any ideas?
Jthmeffy is offline
post #2 of 5 Old 10-25-2007, 01:25 PM
$'s 5th Gen's Avatar
I dont know a whole lot aboout sticks, but that sounds like it could be the pressure plate or throw out bering. Does it do it after it has warmed up?
Sold the 68
Ready for the 2010
$'s 5th Gen is offline
post #3 of 5 Old 10-25-2007, 02:03 PM
Probably the throw out bearing. If you're going to replace it, just replace the clutch...seriously. Most clutch kits come with the bearing anyway.
Devryn is offline
post #4 of 5 Old 10-25-2007, 02:58 PM
This exact problem happened to my buddy's VW Golf (JUNK) and we just replaced the clutch in it and it fixed it.
witchin52 is offline
post #5 of 5 Old 10-25-2007, 11:14 PM
All-American
fbodygrad's Avatar
throw out bearing
and u shouldnt have to hold it in gear
-->00' Z28 A4 Onyx Black T-Tops...T-Rex Cam, 5.3 Heads, 4200 Nitrous Stall, Dana Elite 4L60E, 3.73 10 Bolt.<--
fbodygrad is offline
