question about clutch quick disconnect - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 08-13-2008, 02:34 PM Thread Starter
gss9909's Avatar
I had my CLUTCH, master and slave cylinder replaced in my 99 camaro. Then one night driving home my peddle hits the floor and stays there. look under car and the quick disconnect came loose and I can't get it to stay in every time I put it in and press the peddle down it comes loose again and fluid leaks out from where it connects to the slave. What am I doing wrong and how can I fix this problem?
gss9909 is offline
post #2 of 6 Old 08-14-2008, 06:12 AM
demonspeed's Avatar
Did the plastic white colar thing stay on after it popped out?
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
post #3 of 6 Old 08-14-2008, 08:42 AM Thread Starter
gss9909's Avatar
Stay on? Its loose spins freely. but does stay on the hose. is taht what your asking?
gss9909 is offline
post #4 of 6 Old 08-14-2008, 11:28 AM
demonspeed's Avatar
Yeah, I just wanted to make sure you didn't lose it. IIRC, that's what keeps it held in place. It's been about 4 years since I did a clutch swap on a LS1 F-Body, so I'm a bit rusty. You are definitly going to want to bleed the system once you get it figured out.
post #5 of 6 Old 08-14-2008, 01:05 PM Thread Starter
gss9909's Avatar
how does it hold it in place, its loose? I am so lost.
gss9909 is offline
post #6 of 6 Old 08-14-2008, 06:20 PM
demonspeed's Avatar
Funny thing is, I don't remember. I would check out http://www.ls1tech.com
I assure you that you'll find the answer there.
