Electrical Guru Question--Battery Tender Plus issues.... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 10-10-2008, 04:19 PM Thread Starter
el ess X's Avatar
Ok, on my 2002 Camaro, I don't drive it all that often. I have the Optima red top, about 2 months old. Clean connections (still look new). To keep the battery topped up, I got a Battery Tender Plus, so it's only a couple of months old as well. Up until a few days ago, it's been working great.
So, the other day, I unplug charger, then take the car out for a drive. When I get back, I plug the charger back up. This is where things get weird.
Red and green lights on charger, says red should come on steady and green may be off for a little bit, then it should come on indicating full charge. Red flashing means it isn't hooked up properly according to the trouble shooting guide.
Now, no matter if it's hooked up or not, when I plug it into the wall, the red light flashes and the green light is always steady on. Always. No matter what as long as AC power is applied.
I've checked the in line fuse, it's good. I've checked voltage out put at 22 volts. I've checked voltage across battery when hooked up, >14.5 volts.
I'm worried something's wrong, but this isn't covered in any troubleshooting guide.
Any ideas? Anyone else have this issue? TIA.
el ess X is offline
post #2 of 10 Old 10-28-2013, 03:07 PM
Many thanks for sharing good info…!!!)
Beremenne is offline
post #3 of 10 Old 10-29-2013, 09:59 AM
kc0cmj's Avatar
Get another battery tender.. if it works then you know you have a bad one, if it doesnt work take it back to the store and get your money back.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #4 of 10 Old 10-29-2013, 10:48 AM Thread Starter
el ess X's Avatar
Where were you 5 years ago when I asked the question??
el ess X is offline
post #5 of 10 Old 10-29-2013, 12:06 PM
kc0cmj's Avatar
lol.. sorry, couldn't resist.. that was my poor man's fix it solution..
kc0cmj is offline
post #6 of 10 Old 10-30-2013, 03:25 PM
Well, not worth worring about it cause the fix cost more than a new on at "Harbor Freight" for about 10 bucks.
post #7 of 10 Old 10-31-2013, 05:06 AM Thread Starter
el ess X's Avatar
My point was I asked the question in October....2008!
el ess X is offline
post #8 of 10 Old 11-02-2013, 06:53 PM
Sorry brother I did not notice how old the post was. I hope you found an answer to your problem.
post #9 of 10 Old 11-03-2013, 07:27 AM Thread Starter
el ess X's Avatar
I did replace the battery tender. But the reason the thread got necromanced was because of Beremenne (now banned) idiot spammer decided to resurrect it for some random reason.
Funny, the original post was 8 days before my dog "Rocket" was born...and he just recently celebrated his 5th birthday!!
el ess X is offline
post #10 of 10 Old 11-03-2013, 05:39 PM
Well then "Happy Birthday Rocket"!!!
