V6 - 350 Conversion!!!!? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 11-08-2008, 05:21 PM Thread Starter
I have a 1994 Camaro 3.4L V6. Would a Carburated 350 fit fine? If so is that all, or would I have to do any other mod's to the Powertrain and Suspenion?
Deizel08 is offline
post #2 of 7 Old 11-08-2008, 05:27 PM
Jonz5GEN's Avatar
Yes, the 350ci will fit. I'm not sure about the V6 vs V8 motor mounts, but I'd put new ones in anyway. Since the 3.4L is based on a 60* block and the 350ci is based on a 90* block, I don't think the bellhousings will match up so a new tranny would be needed. Given the opportunity, an upgrade to the rear would be a good idea, but not a necessity.
BTW, welcome to the site.
Jonz5GEN is offline
post #3 of 7 Old 11-08-2008, 05:34 PM Thread Starter
Thanks! What about the Transmission and Suspention?
Deizel08 is offline
post #4 of 7 Old 11-08-2008, 05:38 PM
Jonz5GEN's Avatar
I just edited my first post to reflect the difference in blocks, so please check again. As for the suspension, at the very minimum you will need the V8 equipped F-body struts/springs to compensate for the heavier motor.
Jonz5GEN is offline
post #5 of 7 Old 11-08-2008, 06:42 PM
tazjetman's Avatar
HELLO and Welcome from Tx
Facebook has sucked me into Farmtown.
What can I say I love virtual plowing.
tazjetman is offline
post #6 of 7 Old 01-19-2009, 07:30 AM
350 swap
The K-member is drilled different on the V6. The motor mounts are different between the LT1 and the 3.4 V6/3800 (96-up) and also the LS1. The transmissions are also different. If you go with a carb 350 you will need a different trans to go with it. You will also need that crossmember. You have several different choices, TH400,TH350,TH700R4,4L60E,4L80E. You will also need a different Torque Arm, and driveshaft. The V6 Torque Arm & Driveshaft are quite different from the V8 cars. This information goes for the 93-02 Camaro/Z28/SS & Trans Am/Firebird/Firehawk. The distributor will be up against the firewall, and it IS a tight fit!! All of this can be done, and can be done afforably. A wrecked donor Z28 would be the best help for your swap, or trade up to a Z28 and start modifications! Good Luck with your project!
post #7 of 7 Old 03-09-2013, 04:42 PM
would you need a long or short tail 350 transmission
devin.howell is offline
