Long tube Headers Question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 12 Old 09-18-2009, 08:44 AM Thread Starter
Since the long tube header seem to overtake the space of the stock Cat/Converters, would you just push those back to fit, and would the sensor wiring extend?
Big Red is offline
post #2 of 12 Old 09-18-2009, 08:48 AM
POWERFREAK's Avatar
as far as I know...no LT's will bolt up to the stock exhaust. American Racing (and other's I assume) offers off-road pipes or hi-flow catted mid-pipes. Keep in mind you'll probably have to also get a "tune" to keep your check engine light from coming on.
If you want to keep your stock exhaust you'll need the shorties.
POWERFREAK is offline
post #3 of 12 Old 09-18-2009, 09:18 AM Thread Starter
How much HP benifit would you get out of shorty's?
Big Red is offline
post #4 of 12 Old 09-18-2009, 09:22 AM
POWERFREAK's Avatar
not as much as LT's, but more than I expected...
https://www.moderncamaro.com/forum/sh...t=doug+thorley
post #5 of 12 Old 09-18-2009, 10:31 AM
sscamaro's Avatar
I got Kooks LT headers for my new SS. They have Hi Flo cats that mount up to the OEM "H" pipe. I installed a set on my brother's SS 2 weeks ago. It took us 3 hours to install and they fit perfect. They didn't throw any codes either.
Ralph's Cars
2010 Camaro 2SS/RS, MN6, Victory Red, Polished Wheels,SLP Loudmouth II, Kooks LT Headers, Edelbrock E-Force S/C, Rto-Fab CAI. 546/rwhp & 522/rwtq 2005 C6 Corvette,MN6, Z51, Kooks LT Headers, Corsa Exhaust, Halltech CAI. 388/rwhp 380/rwtq.
sscamaro is offline
post #6 of 12 Old 09-18-2009, 12:39 PM
2010_5thgen's Avatar
whatever headers you buy, they should have the bung holes already in for the o2 sensors. i put borla long tube headers on and the holes were there for me to just screw the sensors into. if you buy one with cats on it, they should be in the same spot as the stock ones and plug in fine.
2010_5thgen is offline
post #7 of 12 Old 09-18-2009, 10:42 PM
camaro1's Avatar
kooks and arh both have long tubes with cats that bolt up to the factory h-pipe(ls3), mid baffle(L99),
415ci stroker,TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts,
camaro1 is offline
post #8 of 12 Old 09-19-2009, 08:57 AM
POWERFREAK's Avatar
Why would you use the factory Hpipe...the AR's come with a 3" xpipe (w/ reducer to 2.5") which will just about get you back to your factory mufflers.
post #9 of 12 Old 09-19-2009, 10:42 AM
HI
The problem with long tube headers is simple. You have to move the catalytic converter. It is a federal offense to remove, move, modify or otherwise tamper with the OEM converter. Any shop that does this can lose their license and be fined. If you do it, you can also be fined.
ford_JJ is offline
post #10 of 12 Old 09-19-2009, 11:48 AM
camaro1's Avatar
not all of them ,, you can get a cheaper version of the arh headers that bolt right up to the factory system, just like the kooks long tubes
http://www.camaro5.com/forums/showth...hlight=arh+cat
the kooks system is just like this and worked out perfect for me because i already had a custom made stainless x-pipe with factory mounting locations
camaro1 is offline
