Radio alway's on?? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 12 Old 05-06-2010, 06:21 PM Thread Starter
ffej0127's Avatar
Radio alway's on??
Ok guy's and gal's I need a favor...next time you get in your car try to put the radio on without using the key.
I know it sounds strange but today mine did just that. I was sitting in my car and I was going to check time, I meant to hit the info button but hit the power and it actually came on.
When the key is in and radio is on, it will go off with the key but I can put it right back on. I even waited past the 10 min run down time.
I never noticed this before because I always turn off radio manually before I get out.
The radio, onstar and my bluetooth will conect when I push the power button.
Could this possibly be normal?? Someone please check theirs.
Thanks
2SS..IO Interior M6 Black Rally Stripes Borla Mufflers Diablo Tuned 20% Tints Vararam ram air, Eibach front and rear sway bars, BMR trailing arms, BMR toe rods, BMR lower control arms, BMR strut tower brace, SLP Long tubes with high flow cats Granetelli cross drilled and slotted rotors BBK 95mm Throttle body Eibach coil overs, BMR Adjustable Front and Rear Sway Bar End Links Bravado 20" Rims with Eagle F1 305/35/20 in the Rear and 275/35/20 front
ffej0127 is offline
post #2 of 12 Old 05-06-2010, 08:44 PM
shawnm3's Avatar
yep, I use mine like that all the time, it's normal
~ Dreams do come true ~
shawnm3 is offline
post #3 of 12 Old 05-06-2010, 10:34 PM
TX_SS's Avatar
That is with the doors closed, right?
TX_SS is offline
post #4 of 12 Old 05-07-2010, 05:37 AM
shawnm3's Avatar
I think you can do it with them open too, but I can't remember exactly...will try it today
shawnm3 is offline
post #5 of 12 Old 05-07-2010, 07:11 AM
cwatson6's Avatar
Its one of those features in the manual that is easily overlooked. This feature has been around for at least a few years on GM vehicles.
cwatson6 is offline
post #6 of 12 Old 05-07-2010, 08:46 AM
sooo sweet, if you ever are sleeping in your car with your radio on and you have had a few drinks you dont need your key. so if the popo come up and ask if your key is in the ingnition you can be like no sir I dont want a DWI for sleeping in my car.
Swissbliss is offline
post #7 of 12 Old 05-07-2010, 09:40 AM
Radio will cut off after 10 minutes without key in ignition (or as soon as you open the door)
post #8 of 12 Old 05-07-2010, 09:44 AM
Thanks
This is just a guess but im thiking its powers everything up when you open the door........I tryed it today and mine came on with no key
post #9 of 12 Old 05-07-2010, 09:50 AM
I play music all the time with the doors open in my garage if you open them 1st and leave em open. with no key
post #10 of 12 Old 05-07-2010, 09:58 AM
Cool good to know thanks
