Question about freeway driving? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 07-19-2010, 01:03 PM Thread Starter
Zako51's Avatar
When I drive home from work everyday I have to take the freeway. The freeway is literally about 100 feet from my driveway at work, so when I pull out of the parking lot at work, I am on the freeway within seconds. My question is...
Should I let my car warm up a bit before I get on the freeway?
Zako51 is offline
post #2 of 7 Old 07-19-2010, 01:11 PM
hddan's Avatar
General Motors did an experament a few years back and came to the conclusion that the best way to warm up an engine is to drive it at moderate speeds until it reaches operating temperature. This produces the least ammount of wear because the car warms up uniformly. I never wait longer with any of my vehicles than it takes for the idle to drop down to a reasonable RPM.
hddan is offline
post #3 of 7 Old 07-20-2010, 06:55 PM
They don't warm up the car in the assembly plant before it hits the chassis rolls for the end of line testing - I wouldn't worry about it unless its below zero out and if it gets that cold in LA you have other things to worry about!
JeffY is offline
post #4 of 7 Old 07-20-2010, 11:05 PM
CyCam1's Avatar
I think the only reason to warm a car up is to get the oil warm enough to do the proper lubricating of the engine and warm the tranny fluid. This is only necessary when it is very cold as it takes a little longer to "thin" out for best lubrication. Warmer climates shouldn't be a problem.
CyCam1
CyCam1 is offline
post #5 of 7 Old 07-21-2010, 04:59 PM
weland's Avatar
I would still wait for the rpms to get down close to the normal idle rpm before pulling out, if I were him.
Do not taunt Happy Fun Car.
weland is offline
post #6 of 7 Old 07-24-2010, 09:16 AM
Supporter of common sense
OverAnxious's Avatar
I would let it run for a few minutes at most. Keep the speed moderate and consistent for a little while once you are on the freeway
OverAnxious is offline
post #7 of 7 Old 07-25-2010, 08:48 AM
407 Driver's Avatar
Owners manual says warmup is not necessary.
Will post reference in a bit.
Hurst Shifter / 3" Magnaflow Competition Cat-Back Exhaust / ADM Performance Street CAI / Body Color Tail Light Bezels / Headlight Armor Tail and Marker Light Kit / Fuel Rails and Plenum Cover
407 Driver is offline
