Oil life monitor question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 18 Old 11-26-2010, 08:04 PM Thread Starter
Warlock's Avatar
I bought my Camaro 13 months ago. Currently it has a little over 3200 miles on it. I did an oil change at around 1300 miles but didn't reset the OLM since it was like at 80%. I was planning on resetting it after the second oil change. On Star keeps sending me reports stating that my car is due for maintenance because of not resetting the OLM for over a year. Is it mandatory to reset the OLM every year? If you don't, can this affect the warranty?
Warlock is offline
post #2 of 18 Old 11-26-2010, 10:20 PM
Ject's Avatar
"every year" ????
You're suppose to reset the OLM every oil change, not every year.
Its not "Mandatory" per say but Highly suggested if you wish it to be accurate.
2SS / RS / A6 Cyber Gray Metallic | Beige Int.
Current Modifications: C.A.I. Inc. CAI, Vmax Ported TB, Dynatech Headers, Flowmaster AMT Cat Back, MSD Plug Wires, Vector Motorsports Tune, Pfadt Drop Springs / Trailing Arms / Swaybars / End Links, Hotchkis Max Brace, Stainless Braided Brake Lines
2011 Modifications: Pedders HD Diff Mounts (EP1167HD), Pfadt Engine Mounts / Solid Subframe Insert, L99 to LS3 Conversion Kit, LS7 Lifters, Ported Intake Manifold
Ject is offline
post #3 of 18 Old 11-26-2010, 11:04 PM
www.camaroscotty.com
Camaro Scotty's Avatar
Will not affect warranty - it is just a reminder. You could reset it now, and again when you change the oil.
http://www.camaroscotty.com
YAHOO IM:
Camaro Scotty is offline
post #4 of 18 Old 11-27-2010, 12:54 AM
How does the OLM work, mileage only? how is it reset? by owner or dealer.
tinpony is offline
post #5 of 18 Old 11-27-2010, 01:57 AM
in my view,IF you save your receipts,you should be fine with a warranty claim.
generally you must provide proof of proper maintenance of the car in order to get it fixed under the warranty,and of course proper record keeping with receipts to back it up should be sufficient...the oil life monitor,should be used as a "guide" to remind you to change the oil!..if you do not set it,then,yes it will affect onstar's ability to perform diagnostics on the car every month!..none of this matters,IF you make a record of the maintenance yourself,of course!
post #6 of 18 Old 11-27-2010, 01:58 AM
you can reset it yourself!..how to do it is in the "owner's manual!"
post #7 of 18 Old 11-27-2010, 06:47 AM
OLM is based on RPMs.
post #8 of 18 Old 11-27-2010, 12:21 PM
You can do it. Cycle the DIC display to show the OLM and then press the button at the end of the stalk and hold to reset it.
post #9 of 18 Old 11-28-2010, 04:06 PM Thread Starter
Warlock's Avatar
Thanks!
Warlock is offline
post #10 of 18 Old 12-04-2010, 08:37 AM
Callaway Chris's Avatar
If it were my car: Reset the Oil Life Monitor, then unplug the OnStar...
Callaway Chris is offline
