Key Fob Question. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 3 Old 12-26-2010, 11:17 AM Thread Starter
meb885's Avatar
Key Fob Question.
My Key Fob is the standard 4 button fob we all have if we have a LS or Manual Transmission car. Difference is, every fob i have seen is made by STRATTEC, my fob says WITTE Automotive. I got a spare fob cheap but it says Strattec, will it be the same frequency/compatible?
WITTE AUTOMOTIVE KEY P/N 13501913
STRATTEC KEY P/N 13500222
Anyone else have keys made by WITTE? if so was your car a early build for 2010 MY?
this is what i see for frequency in my RPO codes....
XL7 FREQUENCIES RATING 315 MHZ LONG DISTANCE 315 MHZ FREQ(XL7)
Car Came home 12/9/2010
2010 2LT M6 Rally Yellow A9100165
Planned Upgrades: RS Style Spoiler✓, Halos/HID's, Body Color XM Antenna. Yellow Accent Panels Upgrades Later: Cat-Back Exhaust, Ground FX, 21" Wheels, Yellow Stitching, SS Bumper
meb885 is offline
post #2 of 3 Old 12-27-2010, 08:15 AM
www.camaroscotty.com
Camaro Scotty's Avatar
Did you try syncing it up?
1. If you have a working key, you can do this yourself. Simply insert a "learned, working key", turn the ignition to "run", but don't crank the engine, then off & remove the key. Next, within 5 seconds insert the new, unprogrammed key & turn it to run. your new key should now operate and the keyless entry code will be learned as well.
http://www.camaroscotty.com
YAHOO IM:
Camaro Scotty is offline
post #3 of 3 Old 12-27-2010, 09:52 PM
Thanks for that info, did not know that. Very helpful sir!
