Question about fog light install on a 2LS - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 10-17-2013, 12:59 PM Thread Starter
xxSkullZxx
xxSkullZxx's Avatar
Hey guys, I recently purchased and installed fog light on my 2012 IOM 2LS, but I think I may have made an error and was hoping you could clarify it for me.
Now everything is hooked up and they work great. I have running them off of the side marker lights. My question is if I should have put on the new bezels first then the lights or the lights and then the bezels? I did lights first and then bezels and there seems to be a tiny gap between the bezel and the light. I did notice when I was putting the lights in that there is an adjuster so that you can get the posts to settle in the holes. I wonder if I go in there and turn that if it would push the lights out a bit?
xxSkullZxx is offline
post #2 of 5 Old 10-17-2013, 02:18 PM
You did it the right way...lights first then bezels. The gap between the lens and the bevel is normal and NOT the result of a faulty install. Here's a picture of my factory installed fog lamp and you can see there's somewhere between 1/8" and 1/4" gap.
post #3 of 5 Old 10-17-2013, 03:01 PM
kc0cmj's Avatar
Has to be a gap so it doesnt rub over time and cause issues with rubbing through the lense that will create a water intrusion.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #4 of 5 Old 10-17-2013, 06:07 PM Thread Starter
xxSkullZxx
xxSkullZxx's Avatar
Cool! Thanks guys. Oh and any else out there that has an LS that wants to immediately make a dramatic change in your cars appearance, get some fog lights. I know NOTHING about cars and it took me literally like an hour to put these in and that was after I wasted about 15 minutes trying to reach in between the tire and the front of the fender well. I finally just got out the jack and took the tires off!!
post #5 of 5 Old 10-17-2013, 07:23 PM
Pumpkin's Avatar
Congrats on the install, this will hopefully be my first mod next spring.
NEOCC Member since 2013
Pumpkin is offline
