Rituals... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 12 Old 11-20-2013, 02:24 PM Thread Starter
Rituals...
Back in the 90s I used to rock a Z28 with a 5.0 and a carburetor. It was an 87, the last year of the carburetor for the F-Body. It was considered a computer controlled carburetor I think...but a carb nonetheless. And I would simply insert the key into the ignition, turn it, and start the car. Every now and again I would have to pump the gas to get it started. But then I bought an 87 IROC with a 5.7 TPI engine. My cousin had a few of them over the years and knew a lot more about cars than I did. So he saw me start the car the same way as I did the Z28 and told me not to ever start the car like that. He said that fuel injected engines are different. He told me to insert the key, turn it to the on position without starting it, listen for the fuel pump to engage, and then start the car after the pump stops. He said you have to let the fuel rails prime and pressurize before starting the car. And I carried that with me to this day. I cringe when I see someone just put the key in and turn it all the way.
But now I have developed an entire ritual for starting and driving my car. Check it out: I insert the key, turn it to the "ON" position, wait for the pump/rails to prime, press in the clutch, start the car, wait for the gauges to go all the way up and back down, then I take it out of gear, release the parking brake, and release the clutch. Before I drive off I press back on the clutch, put the car in gear, and I'm on my way. It seems like a lot, but its actually a quick process.
Parking rituals...when on an incline (front of the car on an upward slope, rear of the car on a downward slope) I use the parking brake and make sure the car is in 1st gear. When on a decline (rear of the car on an upward slope, front of the car on a downward slope), I use the parking brake and make sure the car is in reverse. In my parking lot, I put it in reverse with the parking brake. These are pretty much my only rituals that I keep almost religiously. If I stall in traffic (hey, it happens) then I obviously have to start the car and drive off so as not to embarrass myself or piss off drivers behind me. In my Mustang I do the same process minus the clutch because it is an automatic. But I always seem to leave the radio on the 3rd pre-set and I put all the heat/AC controls facing up...up happens to be the "OFF" position in my Mustang so I put the other controls up so it all looks the same. The Camaro, I never got into leaving the radio on any pre-set. But I usually leave the heat/AC control in the "OFF" position. And I usually on use the heat in the defrost/foot heater control. Maybe this is all a bit weird but in a way consistency shows that you take care of your car.
So I'm wondering if any of you have any procedures or rituals for starting, driving, or parking your car. I hope I'm not the only one, lol!!
post #2 of 12 Old 11-20-2013, 02:42 PM
kc0cmj's Avatar
Not me.. sit down, put seatbelt on, clutch, put key in and start immediately, let clutch out with gas pedal and away I go.
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #3 of 12 Old 11-20-2013, 03:44 PM
I so love my remote start!
post #4 of 12 Old 11-20-2013, 05:59 PM
83Hokie's Avatar
I'd never heard of a starting procedure like that.
about the best I can do is backing into the garage ... down the driveway, curve to the right, into reverse, look up at the camera and start backing to align with the door, once pretty close to straight and near the garage, switch to the side mirrors, make sure clear of the door sides, the dogs, and begin backing again. aim the passenger rear to the corner of the garage, make sure the wife has not angled to far on my side of the garage, back until the beeps are getting louder and the garage wall is fairly close. full brake and park.
83Hokie is offline
post #5 of 12 Old 11-20-2013, 05:59 PM
I get in turn on the key, put on my seat belt, start the car and check the either heater or ac controls as needed.
post #6 of 12 Old 11-20-2013, 07:36 PM
X2 !!!
post #7 of 12 Old 11-20-2013, 07:39 PM
geonny04's Avatar
i was told the same thing back in the late 90's with my first car (fuel injected)and i do the same thing few seconds while in the on position till i hear the fuel pump disengage. now a days i dont think it will matter or else why would they install factoty remote starts which just start it right up. thats just my logic, not that its right. I wonder if this is required still...
2011 2LT Coupe: BBK LT Headers w/ HF Cats. BBK CAI. AirAid TBS. Cat-Back Custom 3" Exhaust w/ Magnaflow Resonated X-Pipe and Pacesetter TFX Mufflers. Aggresive Trifecta 93 Octane Tune w/ Ghost Cam. 18" Advanti Summer Wheels and OEM 18" Stock Winter Wheels.
geonny04 is offline
post #8 of 12 Old 11-20-2013, 08:40 PM Thread Starter
Yes and with push to start I figure you don't really need to do it. I do it more as a force of habit. I've been doing it soo long that I can't start any fuel injected car without letting it prime.
post #9 of 12 Old 11-20-2013, 09:21 PM
vegas girl's Avatar
Originally Posted by JWD621 View Post
X2 !!!
Me THREE !!!!!!!!!!!!!!!!!
2013 2LT/ RS Blue Ray Metallic VERT..."Cami"
2010 Grabber Blue Mustang VERT......."Stella Blue"
January 2014 MC Member of the Month!
vegas girl is offline
post #10 of 12 Old 11-21-2013, 11:29 AM
ChibiBlackSheep's Avatar
I always make sure stuff is turned off before I shut the car off. I don't leave my heater on, rear defroster, etc. Unplug anything plugged into my cigarette lighter.
I use reverse and parking brake no matter what way the car is facing.
2013 IOM Camaro 1LS - Daily Driver
1968 Camaro SS - Weekend Warrior
2000 Monte Carlo SS - CSC Powered Project Car
ChibiBlackSheep is offline
