Duel Mode Exhaust - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 03-20-2014, 11:17 AM Thread Starter
Duel Mode Exhaust
hear all the time about removing the fuse for Duel mode exhaust.
What about just taking off and plugging the vacuum hoses to each side?
What would be the downfall in doing this?
Thanks
Swanys 2SS is offline
post #2 of 10 Old 03-20-2014, 01:02 PM
I'd rather just remove the fuse. I get very cautious when it comes to blocking vacuum hoses. I'd think it might trigger a CEL. I could be wrong.
post #3 of 10 Old 03-20-2014, 03:10 PM
You also should be able to get a remote that will open and close it. I had one on my vette that worked well. I think it was called a mild to wild switch.
StreetSS is offline
post #4 of 10 Old 03-21-2014, 06:57 AM Thread Starter
I just want mine to stay open at all times.
They stayed open and ran fine when hose
had fallen off.
Surprised of how few are chiming in on plugging
vacuum instead of fuse pull.
post #5 of 10 Old 03-22-2014, 07:59 AM
83Hokie's Avatar
had fallen off.
I didnt chime in because I don't have a clue, but wouldn't a hose that has fallen off be the exact opposite of plugging one?
83Hokie is offline
post #6 of 10 Old 03-23-2014, 06:58 AM
big-daddy's Avatar
fuse
Which fuse do you pull?
Big Daddy
Macon, GA
big-daddy is offline
post #7 of 10 Old 03-23-2014, 01:33 PM
big-daddy's Avatar
So I looked at the owners manual and it said the F8 fuse in the rear fuse block is for the exhaust flippers. I opened it and no fuse in the F8 position, I know I have dual mode as I saw the flaps when removing the stock mufflers. What's up with that?
Big Daddy
Macon, GA
post #8 of 10 Old 03-23-2014, 04:55 PM
christianchevelle's Avatar
You have as convertible I do not think they come with dual mode, unless someone installed it afterward I did not think it would fit except for a zl1? You may have aftermarket four tips.... heres a 1le on its side
http://stblogs.hotrod.com/files/2013...03-650x333.jpg
christianchevelle is offline
post #9 of 10 Old 03-23-2014, 07:38 PM
big-daddy's Avatar
got two tips, I had the stock mufflers cut ou and replaced with straight pipes, saw the exhaust flaps just behind the resonators. definitely can tell the difference when they open with no mufflers.
Big Daddy
Macon, GA
post #10 of 10 Old 03-24-2014, 06:04 PM
My dual mode exhaust has no resonators, its just like the pic of the 1le on its side
