How Hard to Add Foglights? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 12 Old 08-28-2014, 09:19 PM Thread Starter
CyberPunk223's Avatar
HOw hard is it to add fog lights to a base car with none? I happen to have already replaced the dash light control switch to one with the fog light button. So in a perfect world the wiring would already installed from the dash down to the front bumper so all I would have to do is buy factory lights, install & lug them in...
could it really be this simple?
thanks
CyberPunk223 is offline
post #2 of 12 Old 08-29-2014, 06:07 PM
christianchevelle's Avatar
wow I simply did the wire harness mod to make my DRL's work as fogs by cross wiring them with the sidemarkers..and adding 13watt LED's and they are bright..... and it also makes the halos always stay on.....and the DRL's stay on with the headlights..... found the info on gen5diy? or somewhere... its just doing two jumper wires form one wire on one harness to the other
christianchevelle is offline
post #3 of 12 Old 08-30-2014, 08:30 PM
I'm interested in doing the same thing please let us know where gen5diy forum was.
Flacam5 is offline
post #4 of 12 Old 08-31-2014, 07:51 AM Thread Starter
I found this, this is the best option I could find so far, this seems much better than buying parts individually off ebay because this is a complete kit with a special designed harness & everything and it even has a 50watt LED option.
LS Camaro Fog Lamp Kit
post #5 of 12 Old 09-03-2014, 06:22 PM
hcso617's Avatar
Good kit, good guy. I did it in less then an hour.
i also added his backup camera kit.
hcso617 is offline
post #6 of 12 Old 09-04-2014, 05:35 PM
Gen5 DIY
post #7 of 12 Old 09-06-2014, 05:04 PM
xxSkullZxx
xxSkullZxx's Avatar
I added the "fog lights" or "DRL's" depending on who you talk to to my 2LS by simply tapping into the side marker lamps. I ordered mine form phastekperformance.com and installed them in like 30-40 minutes and I know NOTHING about cars!
The best way to do it is to use a jack and take off your front tires. Then undo the 3 nuts holding the fender well lining in place. Pull that back to gain access to the fog light holders. Pop out the black place holders and insert the new light kits and new bezzles. Clamp the wires from the fog lights onto the wires that lead to the side marker lamps. Check to make sure they work and put everything back together. Easy peezy!!
2012 V6 IOM./ Borla axel back exhaust/ K&N Cold Air Intake/ 18" TSW Matte Black Mugello wheels, 35 % Tinting, Matte Black Rally Stripes, Matte Black Fade Gill Stripes, Matte Black Fender Hash Stripes, Tail Light and Side Marker Black Outs and Solid Black Bowties!
xxSkullZxx is offline
post #8 of 12 Old 09-07-2014, 07:59 AM Thread Starter
I see that kit already comes with the LED's, I wonder how much power they actually draw, I would be worried about over loading the circuit for those side markers, I already have HID's with a relay control unit that runs off the battery, so I could wire the fog lights to my loose headlight harness... that would definitely have plenty of power to run the fogs.. but it would be easier to get the other kit with the easy plug in harness and get the LED's separately.
post #9 of 12 Old 09-07-2014, 08:24 AM
xxSkullZxx
xxSkullZxx's Avatar
Mine have been installed for over a year now and I have had zero power or overload issues. BTW, how much did the HID lights run you and did you do them yourself?
post #10 of 12 Old 09-07-2014, 05:53 PM Thread Starter
well, I just have hid bulbs in my stock housings, they are from TRS and they have been problem free for 2 years.
