2012 camaro parking brake cable - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 3 Old 11-14-2014, 04:57 PM Thread Starter
tom
Hi,
Can someone tell me if/how to pull out the cable in a 2012 camaro parking brake mechanism. The mechanism I have has about one half inch of the cable showing with the ball on the cable end. thx
tom is offline
post #2 of 3 Old 11-15-2014, 08:44 AM
You can only adjust the system at the rear wheels (which effectively adjusts the clearance of the P/B shoes inside the rotors which in turn reduces the play at the handle. If the clearance is correct and they are not too tight and "dragging" (there should be NO contact when the system is not engaged) then the cable has stretched or some other component has malfunctioned and you would need to have it looked at....
post #3 of 3 Old 11-15-2014, 09:16 AM Thread Starter
tom
Chuck,
Thanks and we will figure out another way to get around only about an inch of cable showing. Putting the assembly into a Chevelle .
As an UPDATE-- Successfully installed the parking brake mechanism and 2012 Camaro shifter in the 69 Chevelle. Should work great with the 2012 Camaro center console, a 6.2l engine and 6l80 transmission..
Thx for the help Chuck.
PS: Still need to know which leads at the shifter operate the neutral safety switch solonoid and at what voltage ?
Tom
tom is offline
