No crank no start. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 2 Old 02-15-2019, 07:32 PM Thread Starter
No crank no start.
I have a 2010 Chevy Camaro SS with a manual trans. 48k miles. My camaro stalled out all of a sudden 12/24/18. It acted as if the fuel pump died. Battery is new, all fuses r good all connections r good. I had the starter tested and its good. I changed the fuel pump, the clutch position sensor and the ignition switch. Im now leaning towards something with the immobilizer. Security light only stays on for the normal 5 seconds. When i turn the key to start, all the lights go out like as if it was going to start but i get nothing. It runs all tests as if it were started. All electronics work, windows work and everything else. I'm trying to avoid going to the dealer obviously bc they will charge an arm and a leg for a $5 part/fix. Would really appreciate the help.
Mark Lisowski is offline
post #2 of 2 Old 02-16-2019, 02:31 AM
If no one responds, you might check other fourms that may be more active, as i havent seen anyone respond to you yet, sorry i cant help, Im not that familure with Manual trans..
