DJ Grilles Predator™ - More Than Just a Pretty Face - ModernCamaro.com - 5th Generation Camaro Enthusiasts
CARiD.com
post #1 of 3 Old 07-27-2012, 10:03 AM Thread Starter
ModernCamaro.com Sponsor
CARiD's Avatar
Hey Guys, we’re excited to let you know that an all-new front grille kit for the Chevy Camaro, by the California-based DJ Grilles, is now available at CARiD.com!
The innovative Predator Grille has not only style but functionality as well. Its radically aggressive design will give your Camaro a compelling high-tech look, while the revolutionary DAC+Falcon RAM Technology will boost the power hiding under the hood of your muscle car.
Make your Camaro's performance even more impressive!
By using the optional Falcon Ram Intake System, you complete the Predator’s built-in Direct Air Channel for maximum performance. Here’s how it works: the grille’s integrated center mounted air duct directs air into the Falcon Ram system, which replaces the factory air box with a cold-air tunnel that routes over the top of the radiator, through a unique low-restriction air filter, and directly into the throttle body, increasing both power and response.
What other styling accessory alone can give your car an additional 20-30 horsepower and 22-35 ft.-lbs. of torque? You can expect even more power (25-35 additional hp. and 35-45 additional ft.-lbs.), once you're ready to retune the ECM for the significant increase in inlet air.
You might wonder how it is possible... We will explain: the stock air intake makes the engine run hotter since it utilizes the already hot air from inside the engine compartment thus making it starve for oxygen. The Falcon ductwork delivers cold air directly from the outside of the engine bay resulting in denser air to burn inside the engine. Due to the location of the inlet as the vehicle gains speed more cold air is directed into the engine. So basically, the faster you drive the better performance you get!
Sounds interesting? You bet! Find out more about the Predator Grille and order yours at http://www.carid.com/2010-chevy-cama...le-872822.html
Note: Kits are offered for 2010 -2012 V-6, V8 Chevrolet Camaros. ZL-1 fitment coming soon!
Chevy Camaro http://www.carid.com/chevy-camaro-accessories/
Call Toll Free: 800.505.3274 | Facebook | Twitter | YouTube
CARiD is offline
post #2 of 3 Old 07-27-2012, 11:01 AM
kc0cmj's Avatar
how about some pictures of it installed?
2010 Camaro 2SS/RS 6spd 426hp
kc0cmj is offline
post #3 of 3 Old 07-27-2012, 11:25 AM Thread Starter
CARiD's Avatar
Just added one
CARiD is offline
