Remote Start - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 06-21-2009, 02:19 PM Thread Starter
Question Remote Start
Is the A/C suppose to come on when you use the remote start. I have all setting on max but only fan comes on until i put key in and turn to start position.... Doesnt do me any good like this
post #2 of 9 Old 06-22-2009, 02:20 AM
CamaroDreams07's Avatar
Oh god I hope not..that sucks..in fact it ruins the point of remote start for me. I thought that it was supposed to remember if you had the air or heat on and then it would do that when you started it.
The Camaro is 100 hp past its competition. The V6 is running with the top of the competition. In other words, if these cars are the whipped cream and the lower trims are the shake, the Camaro V6 is the cherry on top, and the Camaro SS is the person eating the whole ****ed thing.
-The_Blur
CamaroDreams07 is offline
post #3 of 9 Old 06-22-2009, 10:43 AM
CamaroMike's Avatar
That's weird. I haven't heard anything about that. I know that normally, without remote start, the A/C will turn on when I start the car if I had left it on the last time I turned the car off. Maybe check the manual or call a dealer.
Past Camaros: 2000 Camaro SS 6-Speed,
1999 Camaro Z28 A4, 1994 Camaro Z28 A4
Delivered: 2SS/RS CGM M6 - VIN #7460
CamaroMike is offline
post #4 of 9 Old 06-22-2009, 03:54 PM Thread Starter
If you use remote start the A/C should turn on if you leave it set before turning car off. When i use my remote start only the fan runs until i turn the key to start position i have called dealership to research before i bring it in. Might just be remote not programmed right. Also i noticed on my alarm trunk pins arent working cause i have opened trunk several times with alarm set and nothing happened... So you all might want to check yours to make sure its working. Alarm should go off if you open trunk when alarm is on and set(takes 30 seconds to set) and you open your trunk.
post #5 of 9 Old 06-22-2009, 10:16 PM
BLACK10's Avatar
not sure, but that's exactly what our 2005 Pontiac grand prix did. the compressor would not engage until the key was in and in the on position.
BLACK10 is offline
post #6 of 9 Old 06-23-2009, 08:03 AM Thread Starter
After some investigating the A/C works with remote start the lights just dont light up on the A/C control knobs until you turn your key to start position but it blows out cold air. So everything is COOL .
post #7 of 9 Old 06-23-2009, 08:09 AM
Crisis averted.
gto_in_nc is offline
post #8 of 9 Old 06-23-2009, 09:00 AM Thread Starter
Originally Posted by gto_in_nc View Post
Crisis averted.
Amen
post #9 of 9 Old 06-23-2009, 10:51 AM
It's tied into the DIC and when it's cold outside the heater, heated seats and mirrors will all turn on as well. Cool for you cold climate guys!!
Imfishintx is offline
