ECM Location - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 07-06-2009, 09:34 AM Thread Starter
ECM Location
Where is the ECM CHip located?
Big Red is offline
post #2 of 4 Old 07-06-2009, 09:41 AM
1969 LSZ's Avatar
There is no replaceable "chip" used today. The ECM can either be programmed through the OBD diagnostic connector using the proper equipment or the ECM can be removed & programmed using a PC with the proper software.
Several companies offer custom tuning by sending your ECM to them or by taking the car to them. Some may be site sponsors that could respond to this thread.
1969 LSZ is offline
post #3 of 4 Old 07-06-2009, 10:27 AM
the ecm is normally kept in the engine bay, although im not sure where as i havent looking into the engine bay yet. there is no chip, just a solid ecm/pcm that can be removed for sending into tune. no chips
mike25 is offline
post #4 of 4 Old 07-06-2009, 12:18 PM
camaro1's Avatar
right front of the engine bay, cant miss it,, silver with 2 large wire conncetors
415ci stroker,TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts,
camaro1 is offline
