Is there a rev limiter parameter for when the brake is depressed (2010 Camaro)? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 05-06-2010, 04:05 PM Thread Starter
2010 Bumblebee's Avatar
I know it's a strange question, but if there is/was a rev limiter parameter for when the brake is depressed in the 2010 camaro's computer or any car's computer for that matter it could be set just below the RPMs that the torque converter engauges that way one could hold it to the floor and hold the brake and when the light turns green just take your foot off the brake and whá lá a good launch off the line!
Or is could be used as a brake stand protection measure. That way noboby could beat on the car !
So, Is there a rev limiter parameter for when the brake is depressed (2010 Camaro)? Anyone know, or know a work around ??
2010 Bumblebee is offline
post #2 of 5 Old 05-06-2010, 05:10 PM
RedJewel2SS's Avatar
the rev limit in neutral and in park is 4000 rpm, the rev limit in gear is 6200 rpm, there are no other rev limits on the car.
Gone but not Forgotten!
RedJewel2SS is offline
post #3 of 5 Old 05-06-2010, 06:42 PM Thread Starter
I found the rev limiter for each gear including neutral and park. There are also rev limiters by oil & coolant temps. So is there one for depressing the brake that I missed? It's a cool idea isn't it ? Just say you have a 3000 rpm stall converter you could set the rev limiter to 2500, apply the accelerator & Brake, and when the light turns green just release the brake !! 900-1000 RPMs for the stock converter. A good launch every time ! Or like I said it could be used to limit abuse also by not allowing a brake stand.
post #4 of 5 Old 05-06-2010, 07:38 PM
demonspeed's Avatar
Are you an engineer? You are quite analytical (this thread and the A/C one... whew!)
www.fquick.com/demonspeed
Present: '02 SS #7146
demonspeed is offline
post #5 of 5 Old 05-06-2010, 08:16 PM Thread Starter
Just thinking outside the box again. It's the little things that matter..
Good ideas for GM !! They should hire me !!
