octain memory in ecu - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 3 Old 09-14-2011, 03:00 PM Thread Starter
Thumbs up octain memory in ecu
Hay,Did you guys know about pulling the no.5 & 20 fuses out in the fuse box under the hood to reset the ecu back to the high octain mode.It seems that if low grade fuel was used in your car the ecu will back off the timeing to accept it but even if you are useing 93 now it won't reset.You have to pull those fuses and leave them out for 3 or more hrs. then it will reset.I tryed it and what a differance.
bbb10 is offline
post #2 of 3 Old 09-14-2011, 04:38 PM
Yeah. It's all over the board multiple times. It also doesn't take 3 hours.
post #3 of 3 Old 09-14-2011, 05:11 PM
brandonppr's Avatar
https://www.moderncamaro.com/forum/v8...el-camaro.html
brandonppr is offline
Closed Thread
