Lost Power in 2011 V6 - Help - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 27 Old 03-14-2012, 02:21 PM Thread Starter
I have a 2011 2LT RS Camaro, stick shift, that I bought new in May of last year. I have 22,000 miles on it.
When I first got the car I would ride it hard all the time. At one point after about 5,000 miles I checked the 0-60 time with an accelerometer. I was consistently running between 5.8 and 6.0 sec. I didnt check the 0-60 time again after the first 10,000 miles. I was consistently getting 21 mpg during that time. I was always using 89 octane gas.
After about 15,000 miles I got over the need to constantly race and began driving conservatively to improve gas mileage. I started using 87 octane and began getting 24-26 mpg for a tank driving mostly highway miles.
I can't say exactly when but it seems over the past 3 months?? I noticed a drop in power when I went full throttle. I particularly notice it at high rpm. I decided to use the same accelerometer that I used the first time to recheck my 0-60 times and to my horror I was now running between 7.5 and 7.9 seconds.
I looked back at my maintenance records and have changed the oil every 5,000 to 6,000 miles. I did notice that I never changed the air filter. I changed it today thinking that was probably what was wrong but noticed no difference at all.
The only other factor I can add is that do to so many drag runs early in the cars life I did burn the clutch a little. It will slip if I try to power shift. That still doesnt explain the drop in performance because I can still quick shift and feel the pull after the shift. I may have lost 0.5 sec max from that. Other than 0-60 times the car just doesnt seem to pull like it did between 4,000 and 6,500 rpm.
I would appreciate any suggestions.
Thanks,
Rob
Robversion2011 is offline
post #2 of 27 Old 03-14-2012, 02:31 PM
I'm going to stick my neck out here and probably get my ass chewed but here goes...I was having problems with my peddle being sluggish and unresponsive so I did some research.
My Fix: I wound up cleaning my MAF sensor with the MAF cleaner that's available at Autozone. It only took a few minutes and made all the difference in the world. I haven't had the peddle dog on me since and throttle response is immediate. My car only had about 6000 miles on it when I did this and now I'm about to hit 8000.
Maybe this will help...I don't know...but it only took a few minutes to remove it and clean it...the whole process took me less than 30 minutes but you have to let it dry after cleaning...cost of cleaner was under $10.
post #3 of 27 Old 03-14-2012, 02:38 PM Thread Starter
Thanks. I probably will try that if for no other reason than frustration. It's not likely there is any engine wear but I was also thinking of doing a compression test. Is it worth it and if so does anyone know what the specified pressure range is?
I couldnt find it doing a search.
post #4 of 27 Old 03-14-2012, 03:11 PM
I use 87 octane...that's what the car is tuned for. I drive my V6 urban racer VERY hard and average 14-15 mpg so when my acceleration off the line started to diminish I was very concerned. But I experienced immediate results...so I haven't thought about it since. Several months after the cleaning...I added the RX Catch Can.
post #5 of 27 Old 03-14-2012, 04:45 PM
2016 Camaro 1SS
mojave's Avatar
Envy ! You must flog her to get 14-15 ! IMO that is awesome : ) I cleaned mine also since I went to the dealer and they said it needed to be done for $130 : ( So $6 later I did it myself. It was dirty but $130 was not happening. I could get a nice mod for that
mojave is offline
post #6 of 27 Old 03-14-2012, 04:46 PM
post #7 of 27 Old 03-14-2012, 04:51 PM
Yep...so easy a girl could do it...lol.
post #8 of 27 Old 03-14-2012, 05:24 PM
2016 Camaro 1SS
mojave's Avatar
Only a few power hungry people could do it !
mojave is offline
post #9 of 27 Old 03-14-2012, 05:59 PM Thread Starter
The good news is that your solution worked perfectly. It was like it came alive suddenly and I had a new car again.
Bad news is I missed a power shift going into second gear and applied so much force on the shifter that now I am SCREWED!!!!!!! I felt the whole car vibrate from the grinding. Totally destroyed my transmission. Not only can I not shift into first or second gear but if I ease it into second under gentle throttle it sounds like a drill boring through cement.
I can't imagine how much this is going to cost me but I feel horrible. I doubt there is any chance my warranty will cover it either. I was better off with my slow working Camaro. This sux.
Anyone have any idea what a worst case scenario price could be? Second order approximation is all I want. We talking possibly $1,000, $1,500, $2,000. Any possible way to get a mechanic to get warranty coverage somehow?
Anyway if someone searches for power loss and comes upon this thread maybe it will help them.
post #10 of 27 Old 03-14-2012, 06:37 PM
Wow...that doesn't sound good. Why wouldn't your warranty cover this? Have you done some mods?
