2012 V6 with a p0960 code!!! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 04-26-2013, 01:52 PM Thread Starter
Go to start the car this morning and i get Reduced Engine Power and Stability Track Service message.. then all the lights are on.. so i let the car sit for a while.. come back out.. and its running fine with just the check engine light on.. go for a ride.. stop at the store come out.. check engine light is off.. start driving stop at another store.. come out.. and BOOM Reduced Engine Power again.. Code read p0960 Fuel Pressure Regulator something something something.. and another code that had no definition. Im at a loss. Has anyone else ran into this issue??
I have an appointment at the dealer on Tuesday.. guess I do not get to enjoy driving over the nice weekend..
FYI the only things i have on my car is a Strut Tower Brace. I upgraded the headlights to the Eagle Eye Projectors and added Driving Lights.. then i just put in 35 watt 8000k HIDs in all 4 lights..
For the Halo Rings I tapped into the parking light for the relay and the power is coming from the accessory switch.. this also is the power for the driving lights.
Any help would be appreciated.
Havock is offline
post #2 of 4 Old 04-28-2013, 06:56 PM Thread Starter
it appears that my HIDs may be causing the issue somehow.. I disconnected all of my headlights and fog lights.. and the issue appears to have gone away.. the check engine light even turned off.. thats weird.. anyone have any ideas why my HIDs would cause such an issue.. do they take that much power..
Havock is offline
post #3 of 4 Old 04-30-2013, 01:04 PM Thread Starter
Figured it out.. I had the HIDs wired HID Bulb - H9 Wiring Harness / Ballast - H13 Factory Wiring. What I needed to do was use my H13 Harness from my old HIDs which wires into the accessory and grounds each side to the car and plugs into the passenger side H13 factory harness so I eliminated using the H9 harness completely.. This resolved the issue. Still not sure how this screws with the sensors unless its sending feedback through the harness to the ECU. Car has been running fine for the past 3 days and no more CEL
Havock is offline
post #4 of 4 Old 04-30-2013, 01:22 PM
skuttduck's Avatar
That's weird.
Glad you figured it out.
skuttduck is offline
