Codes P1133 P1153 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 07-01-2013, 03:23 PM Thread Starter
MidnightSSS's Avatar
Unhappy Codes P1133 P1153
Got them on my car and its has a full custom dyno tune, any idea of how and why?? car still runs fine just have a light on
April 2013 COTM Winner
MidnightSSS is offline
post #2 of 19 Old 07-01-2013, 04:16 PM
Something with your O2 sensors
Order #: VBBDZ1
2017 Camaro ZL1
Ordered: 12/26/16
Blue10CamaroSS is offline
post #3 of 19 Old 07-01-2013, 04:18 PM
GM: P1133 HO2S/O2S Insufficient Switching Sensor 1 Or Bank 1 Sensor 1
GM: P1153 HO2S Insufficient Switching Bank 2 Sensor 1
O2's may be dead or you are using extenders (known issues) or the tuner tuned them out but the ECM is still "looking" for input from them....
post #4 of 19 Old 07-01-2013, 05:07 PM Thread Starter
Yup thats exactly what it read, well everything is brand new, i made sure all the connectors were tight and connected, no burnt wires everything all tucked up and clean, im hoping its not looking for them, i have to contact my tuner and ask him, idk what else i can do??
post #5 of 19 Old 07-01-2013, 05:11 PM Thread Starter
the car only has 13k on it, is it maybe because i never disconnected the battery when doing the headers and before the tune??
post #6 of 19 Old 07-01-2013, 05:35 PM
That shouldn't cause those codes to throw...but don't worry...your tuner should be able to take care of the problem.
post #7 of 19 Old 07-01-2013, 05:53 PM
OK, but because the O2's are now farther downstream they may not be getting up to normal working temps where "switching" occurs or they may have fouled... I have not seen the actual tables for them in tuning software but IIRC, there are separate tables to disable them in for both operation and readiness checks....
post #8 of 19 Old 07-01-2013, 06:36 PM
Problem is caused because the 02's are not being heated up enough after installing the long tube headers causing issues when switching from open to close loop. Your tuner can delete the codes for good.
JULY 2013 M.O.M winner!
Strick is offline
post #9 of 19 Old 07-01-2013, 06:38 PM Thread Starter
ok cool thanks, so im guessing this is a common problem?? have u guys had an issues with yours doing that?? i can still drive the car without hurting it??, so it def sounds like its a tuning issue then..
post #10 of 19 Old 07-01-2013, 06:53 PM
ModernCamaro.com Sponsor
yes, those are common codes that get thrown due to lt headers... you need a tune....
06MonteSS is offline
