2010 Keyless Entry Remote Programming - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 4 Old 12-29-2014, 05:58 PM Thread Starter
Is there a way I can program a keyless remote for my 2010 Camaro SS? I broke mine and ordered a new one from the dealer but they want $72 to program it!
Luke77515 is offline
post #2 of 4 Old 12-29-2014, 07:51 PM
If you still have one remote that works you can program an additional one with the following steps...
1) stick old key into ignition and turn to "on" (it's the position before "start")
2) turn off and take out old key
3) quickly (like a few seconds) insert new key and turn to "on"
Takes less than 10 seconds and then there should be a new key programmed message in the DIC.
But if you don't have a working remote you are SOL and will have to pay the dealer.
post #3 of 4 Old 12-29-2014, 08:03 PM Thread Starter
My keys are not attached to the keyless entry remote, as per the factory recall. I have 2 keys, separate from a keyless remote which both work fine, and a keyless remote which isn't programmed that just came in today. How do I get the keyless remote programmed other than going to the dealer?
post #4 of 4 Old 12-29-2014, 08:26 PM
A locksmith can do it and they usually charge less than a dealer...just call a couple and ask for some quotes.
