General mechanical question - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 07-23-2008, 12:39 PM Thread Starter
classicrockr's Avatar
Ok guys - i need some help. In order for me to get my new Camaro, I gotta make sure my 2003 PT Cruiser is working fine so my son can have it. I'm having a slight problem with it:
When sitting still (tranny in "D"), if I have the AC or fan on, the engine begins to cycle or shake kinda heavily every 1-2 minutes. It only does this for a couple of seconds, but it makes it hard to have the AC or fan on. If I'm driving, it won't do it - it runs fine the AC & fan work fine.
I've had the battery checked & an electrical system check done - both times they told me "we can't find anything wrong".
- The car has 107,000 miles on it
- Original battery, alternator, etc.
Any help is appreciated - like I said, if it works fine for my son, then I get my new Camaro........
classicrockr is offline
post #2 of 8 Old 07-25-2008, 06:05 PM
Looks like there is a problem with the wires sold for these cars: PT Cruiser forum
I would try changing those out and then checking for a torn gasket. Sounds very similar to the problem experienced by the person in the forum posted above.
Hope that helps!
Last edited by Norah; 07-25-2008 at 07:13 PM. Reason: I can't read. Spark plugs changed to wires
Norah is offline
post #3 of 8 Old 01-17-2009, 10:01 AM
REDREIGN's Avatar
Get rid of the PT crusier, they are the worse car Crysler has ever built, i see them in the shop all the time, if its not the engine its the, electrical or the tranny, sell the car b4 you cant, just a suggestion.
1991 Z28 CONVERTIBLE, 383CI,
[http://www.darkreignstudio.com
REDREIGN is offline
post #4 of 8 Old 01-18-2009, 09:06 AM
Would start with maintance. Has it been tuned-up?
Mase is offline
post #5 of 8 Old 01-19-2009, 04:51 PM
Moderator
slims00ls1z28's Avatar
Idle air control sensor/valve, or whatever they call it on that particular car, It is supposed to raise the idle when the AC is on. If it is sending out faulty signals it could do that as well. Any SES lights comming on?
slims00ls1z28 is offline
post #6 of 8 Old 03-27-2009, 04:31 PM
I second this post. Check the IAC. It is not uncommon for them to fail.
MorePowerMike is offline
post #7 of 8 Old 03-27-2009, 05:34 PM
Jonz5GEN's Avatar
This thread was from last July, but it's all good if another peep learns something new.
Jonz5GEN is offline
post #8 of 8 Old 03-27-2009, 06:05 PM
oh man.. I see that now. Whoops.
