Teaser: Camaro RGBWA DRLs from Diode Dynamics! Multi-color w/Switchback! USA Made! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 2 Old 09-15-2016, 11:58 AM Thread Starter
ModernCamaro.com Sponsor
Diode Dynamics's Avatar
Arrow Teaser: Camaro RGBWA DRLs from Diode Dynamics! Multi-color w/Switchback! USA Made!
Teaser: Chevrolet Camaro RGBWA DRLs from Diode Dynamics!
Full RGBW Multi-color functionality w/integrated Switchback Turn Signal featurel!
The only USA Made LED Board Replacements! :usa2:
These modules are a direct replacement for the factory-installed headlight LED panels in the 2016+ Chevrolet Camaro equipped with the premium package headlight housings.
From the factory, the DRL LEDs in the headlight are illuminated by a circuit boards that holds white LEDs. Our RBGWA multi-color board is a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA.RGBWA - The replacement panels utilize RGBW and Amber LED chips for full multi-color functionality, a crisp true white color, and a bright amber turn signal with plenty of output for daytime visibility. The white setting will have more visibility than the OEM-white
PWM DRL Brightness Settings - Our DRL LED board replacements also feature built-in PWM dimming to retain the low-power and high power settings for daytime and nighttime use, for a true OEM quality effect.
Remember, this product is not just RGBW - it is RGBW-A! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips, in addition to an amber LED for the turn signal function. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
For OEM-grade reliability, the LEDs are protected by a thermal management system, which is integrated into the panel and driver. If the temperature of the LEDs becomes too high for any reason, the output of the LEDs will decrease, to ensure long life in even the harshest environments. And of course, the advanced constant-current driver ensures that there will be no damage to the LEDs long-term from the harsh electrical system of the vehicle.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
This product will be available in early October and is made right here in St. Louis, Missouri!
Expected Retail Pricing:
RGBW - $180
RGBWA - $220
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 2 Old 06-07-2019, 03:31 PM Thread Starter
THE WAIT IS OVER!
Our Multicolor LED Boards for the 2016-2018 Camaro and 2019 Camaro ZL1 are available NOW!
Jake H.
Diode Dynamics
