1st Convertible Onstar/XM Fin relocation (I think) - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 03-20-2011, 07:31 PM Thread Starter
Pony's Avatar
Now you see it…..1st Convertible Onstar/XM Fin relocation (I think)-fin-.jpg Now you don’t!!1st Convertible Onstar/XM Fin relocation (I think)-fin-off.jpg
First off If your not willing to fit yourself into your trunk, you may wish to rethink this DYI. 1st Convertible Onstar/XM Fin relocation (I think)-monkey.jpg
All in all this was a fairly simple DIY. You will have to seal the Fin location on the trunk deck, but if you're painting rally stripes on this can be down at that time. This is not meant to be the "last word" on final location, but it worked for me and XM/ONstar work just fine. There are some steps that are not step by step, but if you cannot figure it out you shouldn’t attempt or can PM me. So......
After exposing the trunk by removing all plastic retainers you will remove Fin by removing 1 bolt and unclipping the plugs. The fin will need to be removed from the actual antenna by removing 4 #8 torx screws.
Carefully remove these two antenna wires from the main wire harness. Once you get back by the taillights there is another rolex connecter to unplug leaving about a 2 foot section of the antenna disconnected. You will use this later in the rear seat area to connect to the XM/Onstar antenna.
1st Convertible Onstar/XM Fin relocation (I think)-trunk.jpg
Continue removing the two wires and re-taping the wire harness until you reach the top of the wheel well, or even with the back of the trunk as shown below 2 pics. There is a gray foam block here for reference and a nice place to zip tie the onstar/xm cables in place. I covered the cables with a plastic wire protector as seen in the pics.
1st Convertible Onstar/XM Fin relocation (I think)-routing-1.jpg
The antenna cables will ultimately be tucked in behind the trunk liners as shown by the yellow lines. The Circle with X will be where the cable passes into the rear seat area.
1st Convertible Onstar/XM Fin relocation (I think)-routing-2.jpg
You will first need to remove the side and rear plastic trim pieces. These are just clipped in and gentle prying will remove. NOTE: The rear trim piece is made up of two pieces molded together. Make sure you get under the main honey comb piece shown in later pics.
1st Convertible Onstar/XM Fin relocation (I think)-side-trim.jpg
The yellow circle below is where the antenna will ultimately be located.
1st Convertible Onstar/XM Fin relocation (I think)-rear-trim.jpg
Now release the rear seat cushion. This is done by placing a screwdriver in the respective holes on each side and giving a firm “pop”. The seat will fold down.
1st Convertible Onstar/XM Fin relocation (I think)-seat-release.jpg
You will remove the two plastic retainers (only 1 shown) so you can fold back the rubber insulation. This allows access to grab the antenna wires from the trunk.
1st Convertible Onstar/XM Fin relocation (I think)-rear-exposed.jpg
At this point you will need to fabricate some form of mounting bracket. I utilized a 50 cent flat iron from Menard’s and bent it as shown. It is approximately 1 ˝ inch from the top of the bracket to top of antenna. This allow for it to fit under the rear plastic trim shown later.
1st Convertible Onstar/XM Fin relocation (I think)-bracket.jpg
You will also need to drill in the bracket indicated by the yellow circle below. You will also need to measure and mark holes in the metal rear deck frame and drill holes for the mounting bracket. I utilized 2 small flat head bolts and nuts with locktite. Plug in the 2 foot antenna removed from the trunk into the end that you passed through from the trunk into the rear seat area, and then plug into the antenna when needed.
1st Convertible Onstar/XM Fin relocation (I think)-mounted.jpg
The last step you will need to do is cut out some of the honey-comb plastic on the rear trim piece so it will lay over top of the onstar antenna without hitting it.
1st Convertible Onstar/XM Fin relocation (I think)-cut-trim.jpg
All you have to do now is reassemble 1. Rubber mat. 2. Rear Seat. 3. Side trims 4. Rear trim.
My XM radio worked fine and onstar operator was able to locate my exact position. For fun, I actually covered the Antenna with a metal bucket, and still had reception.
__________________
[IMG][/IMG]
Proud owner of Litho #198
Pony is offline
post #2 of 19 Old 03-20-2011, 09:09 PM
TX_SS's Avatar
Excellent write-up, great contribution for those wanting to rid themselves of the famed shark fin
TX_SS is offline
post #3 of 19 Old 03-21-2011, 08:02 AM
I'll 2nd that TX_SS!!!!
post #4 of 19 Old 03-21-2011, 08:20 AM
2010_5thgen's Avatar
is that black and red interior?!
Brixton Forged
2010_5thgen is offline
post #5 of 19 Old 03-21-2011, 08:35 AM Thread Starter
Pony's Avatar
Not exactly "red", but close enough
__________________
[IMG][/IMG]
Pony is offline
post #6 of 19 Old 03-21-2011, 08:53 AM
SWEET !, Nice job pony +
post #7 of 19 Old 03-21-2011, 09:26 AM
its not stock is it?
Brixton Forged
post #8 of 19 Old 03-21-2011, 09:32 AM Thread Starter
Pony's Avatar
No. It's a custom interior. I have the rear seat in and door/dash panels. Will be installing the front seats the end of this week. Will then post more pics.
__________________
[IMG][/IMG]
Pony is offline
post #9 of 19 Old 03-21-2011, 09:44 AM
SS-Eric
SS-Eric's Avatar
Awesome Job!!!!
SS-ERIC
SS-Eric is offline
post #10 of 19 Old 03-21-2011, 09:52 AM
Hylton's Avatar
Great idea and job!
"BBOMG - More than just a car show.....it's an experience!"
Need to contact me? layssenATaol.com
Hylton is offline
