Removing Center Gauge Bezel - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 06-25-2011, 06:56 AM Thread Starter
dragom's Avatar
I installed this a couple of months ago and thought maybe someone else would like to know how to remove it to put the new bezel in. First you need to have a screw driver or something to pry the tabs on the frame.The left and right have the same clips so I just took pictures of the right side already taken off. You can see where you have to add a little pressure to undo the clips.
Here is the back of the bezel to get an idea of where you need to pry.
Once you have the center gauge bezel loose there is still a hard plastic and rubber piece that is attached to the top cover of the steering wheel.
Here is the piece still attached to the Bezel.
The bottom soft rubber part is what you will have to pry loose from the steering wheel cover but it comes out real easy just be patient and take your time. Here is what it is attached to.
Once you get the soft rubber tabs pulled away from the steering wheel cover you can pull it out.
Now you need to get the hard plastic off the center gauge bezel. I took pliers and squeezed the clips and slide if off the pod.
Which you will end up with this::
To install the new one is pretty much just putting it back together.
Here is the finished product.
dragom is offline
post #2 of 7 Old 06-25-2011, 07:04 AM
PNYSLAR's Avatar
very nice paint unique
2010 Camaro's are GM's best idea yet!!!!
2SS/RS Black on Black, M6 Sunroof
2012 Summit White ZL1, M6, Sunroof
"Thank you Champion Chevrolet!!!!" #1588[
PNYSLAR is offline
post #3 of 7 Old 06-25-2011, 08:38 AM
Sweet, great job, thanks posting this & pics
post #4 of 7 Old 06-25-2011, 08:41 AM
Buzz's Avatar
Nice job
Buzz
2010 Synergy Green 1LT
Buzz is offline
post #5 of 7 Old 06-28-2011, 10:04 PM
Thanks for the pictures and info, it's this type of information freely given by all of the great people here that really make this forum tick!
Thanks again!
post #6 of 7 Old 10-15-2011, 09:37 PM
Thanks for the write up. Just ordered IOM bezel for mine and was wondering how to install.
post #7 of 7 Old 10-17-2011, 06:35 AM
Nice will have to mark this..
