How to: Gain Horsepower By Pulling the Fuses In A Late Model Camaro - Page 2 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #11 of 31 Old 05-28-2012, 01:21 AM
Well I did the pull and I noticed no difference. Maybe it isn't as pronounced on the LS3 engine as it is on the L99...
post #12 of 31 Old 05-28-2012, 02:03 AM
Moderator
slims00ls1z28's Avatar
You have a tune where the LTFT's are already modified and adjusted to levels probably higher to the factory high trims so I wouldn't expect to see anything on a tuned car already.
slims00ls1z28 is offline
post #13 of 31 Old 05-29-2012, 01:41 PM
amz
amz's Avatar
Doing the fuse pull won't change what the tuner did , right?
amz is offline
post #14 of 31 Old 05-30-2012, 12:23 AM
If your car is tuned then you don't need to do the fuse pull. But if you did it then the tune will not be affected. I did it on Sunday and I have a Predator tune.
post #15 of 31 Old 06-06-2012, 07:08 PM
My SS has no tune, but ive read that you also need to disconnect the battery?
Vintage-Iron is offline
post #16 of 31 Old 06-06-2012, 08:29 PM
Nope, just do the fuse pull and give it an hour or two that's all.
post #17 of 31 Old 06-15-2012, 06:30 PM
is there a noticeable difference when you do the fuse pull?
post #18 of 31 Old 06-15-2012, 08:03 PM
Provided it had low octane fuel in it at one time, and now has super in it, the difference is quite dramatic.
post #19 of 31 Old 07-06-2012, 02:58 PM
Joe Wintle's Avatar
I did the fuse pull yesterday and have noticed that my 2012 SS
Runs much smother. No bumps or pops at low speeds. Better than
When I picked it up in march. Factory/dealer must have put low octain
Fuel in it.
Joe Wintle is offline
post #20 of 31 Old 07-07-2012, 01:10 PM
james591's Avatar
pulling fuses today, I had some bad gas and have run 5 tanks through with still a small hesitation at low RPM, more noticeable when warming up, kinda studders a little during the accelration.
08/04/09 - 2010 Camaro SS, Victory Red w/Silver Strips, 6 speed manual-
james591 is offline
