Speed Inc's TVS2300 2010 camaro results - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 11 Old 08-01-2009, 09:58 AM Thread Starter
ModernCamaro.com Sponsor
Bryan @ Speed Inc.'s Avatar
so... bad day to go to the track and try and get a feel for the new setup. The ride was over 2 hrs in traffic and then over 1 hr in tech. We gave the car about a 15 minute cool down and went for it.
car just turned 1000 miles on the trip up to the track
1/2 tank of 93 BP
race weight..I would say 4K
tires were M&H 345/35/18 : http://www.mandhtires.com/store.php?...on=show_detail
2 runs is what I got...Jim got one off and Dan had a clutch pedal on the floor issue.
#1 tried a 3800ish launch with a smooth, but quick clutch release which resulted in a little spin and hop which I quickly pedaled through. I power shifted at approx 6500 ( stock tach ), but it did not seem to like the power shift at times...slight hesitation since I think the flare would hit the limiter. I tried to run out 3rd gear, but just short of the stripe the car nosed over from the limiter.
2.1 60ft
91 1/8
12.38
119.5
#2 was about 1 hr after the above mentioned clutch pedal stuck on the floor for Dan I decided to try it again. The hood stayed shut for the time it was sitting and the clutch still had a horrible smell. I worked the car through staging for about an hr and then finally got the second run. I came out at approx 3200 ( worried about clutch ) with a quick, but smooth clutch release again and had just a touch of spin/hop and stayed in it. The run felt good here...did not power shift 1-2 and shifted about 6200 on all gears + pulled 4th this time.
1.84 60ft
93 1/8
11.87
118.4
We really feel a gear or shorter tire would really help the car work well both on the front and back of the track
so we are very happy with the car considering lack of time last night to get a feel for the car. We will get back out and work the ET some very soon.
Bryan @ Speed Inc. is offline
post #2 of 11 Old 08-04-2009, 11:28 AM
yota73's Avatar
Yeah you could do a whole lot better. Not bad though. Hell the Hennessey with the same charger, drag radials, intake, and exhaust runs an 11.67 @ 121mph. Kepp it up you'll get that suck deep in the 11's
Proud owner of a 2005 srt-4 on less boost and heat soaked put down 372whp and 395wtq. Building my 1973 celica hopefully running before police academy starts. Can't wait to own a new car off the lot. Looking into the 1lz
yota73 is offline
post #3 of 11 Old 08-13-2009, 10:24 AM
went 11.80 a couple days later, but the huge rear tire is killing the top end
Hennessey had a short rear tire and that alone with good weather could get us to a .60 or better and better MPH.
edit: sorry he was on a 20" tire which should be close to stock height
it must be nice to have a track a few feet away to test on with a cool car
We will be back out testing soon with the revised combo.
10% overdriven crank pulley
3.6 upper ( was 3.8 )
upgraded HE reservoir
new injectors
MagnaVolt boost-a-pump
*still full stock exhaust
We will be testing on a M/T 315/18 which is 26" tall compared to the 28"+ M&H from last time out too.
should be a big improvement
[email protected] Inc. is offline
post #4 of 11 Old 08-15-2009, 08:59 PM
yota73's Avatar
Yes cool weather is a huge treat.
yota73 is offline
post #5 of 11 Old 09-02-2009, 01:06 PM
$'s 5th Gen's Avatar
Something Hennessey doesn't have.....yet
Sold the 68
Ready for the 2010
$'s 5th Gen is offline
post #6 of 11 Old 09-16-2009, 01:28 PM Thread Starter
We will be heading out to Great Lakes Dragaway this Friday to test the new combination!
new injectors
Dynatech long tube headers, SLP loud-mouth 2
(Dyno'd 580+rwhp and 530rwtq)
we will also be running MT315/35R18's (26" tall) instead of the huge 28" tall M&H's we had on there from the previous runs. hopefully we'll have some decent weather!
post #7 of 11 Old 09-16-2009, 03:39 PM
OctaneZ28's Avatar
Nice! Looking forward to the new numbers.
What wheels are you guys using on the rear?
OctaneZ28 is offline
post #8 of 11 Old 09-16-2009, 11:15 PM
SS1_2010's Avatar
yeah I was wondering about the wheels also or did you just plug off the brake lines and remove the caliper like everyone else is doing
SS1_2010 is offline
post #9 of 11 Old 09-23-2009, 09:20 AM Thread Starter
Well the air wasn't great. high humidity. we were fighting traction all night. heel hop didn't seem to be as much of an issue with the shorter rear tires vs the 28" tall d.r.'s we ran before.
The mph shows decent improvement in the humid air, but the e.t. wasn't matching up with the mph no matter what we tried.
best two runs of the night were as follows:
me driving:
60' - 1.84
1/8 mph - 96.69
1/4 et - 11.72
1/4 mph - 122.59
Larry driving:
60' - 1.88
1/8 mph - 97.27
1/4 e.t. - 11.70
1/4 mph - 122.43
we got to the track after 2 hours of driving, paid, got through tech right away and only had a half hour cool down. that was the longest the car sat to cool the whole night. there were no super long cool downs, no icing the blower, or any of that non-sense. i even hot lapped the car a couple times as i was trying to just get a feel for the car as i had not even sat in the thing until that night. ha.
the wheels we are using are repro 18" C6 Z06 wheels, with a 315/35 drag radial. we did have to cut the cables to the E-brake so they would fit.
post #10 of 11 Old 09-23-2009, 10:02 AM
hot weather is a also huge treat?
Do you think so?
ford_JJ is offline
