Best shift RPM??? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 02-18-2010, 01:39 PM Thread Starter
sportfisher's Avatar
Best shift RPM???
What is the best RPM to shift at on a six speed LS3 for max 1/4 mile speed and ET? Thanks, Sportfisher
sportfisher is offline
post #2 of 9 Old 02-19-2010, 12:05 PM
jnm2003's Avatar
find out where it tachs out at and shift like im guess in around 67 or 6800(give or take) i know from the distance from where my red starts on the tach)and push in the clutch right at 100 or 200 rpms before that. If you practice it enough and u have exhaust on ur car u can listen to the car as its reving and get used to the pitch and learn when its at that rpms.
2010 1SS IBM M6
ordered Oct 19
delivered Dec 4
jnm2003 is offline
post #3 of 9 Old 02-19-2010, 02:20 PM Thread Starter
I was looking for a more technical answer based on HP and torque curves.
post #4 of 9 Old 02-21-2010, 09:08 PM
Carlos Garza's Avatar
what works better for me is to shift around 6200 rpms. No 2 cars are alike, so if you are looking for the optimal shift points in your car you need to make an appointmen at the local dino and do a few runs.
Carlos Garza is offline
post #5 of 9 Old 02-22-2010, 01:58 PM Thread Starter
Are there any rev limiters built in?
post #6 of 9 Old 02-22-2010, 06:42 PM
BobGreenTX's Avatar
Yes, there is a rev limiter. The first time down the track I was not watching the tach because of the launch and it bogged down at about 7000
BobGreenTX is offline
post #7 of 9 Old 03-04-2010, 09:40 PM
z28greaser's Avatar
What kinda of gear does the new camaros have?
358ci SBC 400+hp Double hump Vette heads port and polished, valve job, shaved,weiand stealth intake and 750 edlerbrock carb
z28greaser is offline
post #8 of 9 Old 01-05-2011, 05:05 PM
young guns's Avatar
The SS m6 has 3.45 gears, sounds like alot of people are switching to 4.10 gears and are pretty pleased with the results.
Transmission:
TR6060
1st 3.01
2nd 2.07
3rd 1.43
4th 1.00
5th 0.84
6th 0.57
Final Drive Ratio 3.45
young guns is offline
post #9 of 9 Old 01-06-2011, 06:44 AM
ModernCamaro.com Sponsor
Tampa Tuning's Avatar
Tampa tuner camaro corvette tuning www.tampatuning.com
If you have a scanner, you need to scan to see when your manifold pressure starts to drop off. That will keep you in peek power. Sure you can shift a 6300 Rpms, but your power band dropped off about 500-600 Rpms before that.
Although stock with 4.10 gear I think you'll need the additional shift to 5th gear for quarter mile racing.
Tampa Tuning is offline
